Tony Wildman w/MTW stage 2 - Ford Powerstroke Diesel Forum
post #1 of 61 Old 06-03-2013, 03:20 PM Thread Starter
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
All I can say is WOW! I went from running the srl (stock turbo tune) to Tonys extreme with early lock up (MTW turbo tune) and my truck is a completely different animal. Tons more power with lower egts! Tony has the MTW turbo tuning figured out. It's easy to tell that Matt's srl holds back fuel because with Tony's extreme leaves a hazes of smoke the turbo can't clean. I'm actually surprised this turbo isn't cleaning all the smoke on he top end. Once I learn to keep my foot out of it I will report back with some hand calculated mpgs. As for now, I'm going to make an appointment with the local tire shop for some extra rear tires
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #2 of 61 Old 06-03-2013, 06:18 PM
what injectors?
06 f350: 8" ICON 2.5 resi's, ouo ala's, pmf track bar, dual stabilizers, custom 5" exhaust, 37" BFG km2's, 4.30s, 08 tailgate w/step, 08 tail lights, coolant filter, BPB oil cooler w/p 58v ficm and radiator, ARPs, 175cc, MTW s1 billet, ported intake, egr delete, onboard air and gearhead tunes
All the above just to haul the 900hp street mustang
94slowbra is offline
post #3 of 61 Old 06-03-2013, 07:45 PM
Fox Hunt's Avatar
Quoted: 30 Post(s)
Umm if your on stock injectors you have a problem. Stage 2 should be more than enough to clean them up. My hybrid can so a stage 2 definitely will. I too run a tune from tony.
Sent from AutoGuide.com App
2006 F-350 CCSB Lariat
MBRP 4" Exhaust, ARPs, Barder Stage 2 turbo, S&B CAI, TSD SPD, Warren Competition transmission, Edge CTS, Coolant Filter, High Idle Mod, CCV Mod, Zoodad, Newton Leveling kit, Fuel Mavericks 20x9 , Pioneer DVD head-unit, JL Stealthbox and JL Slash 500/1v2 amp
Future Mods:
Injectors and Driven Diesel RR
-Alex
Fox Hunt is offline
post #4 of 61 Old 06-03-2013, 08:13 PM Thread Starter
Quoted: 8 Post(s)
Yep I'm running stock injectors... I'm waiting for tony to return my email. My ipc numbers are probably my issue. My truck runs like a raped ape!!!! So I can't wait to see if I can make it more efficient which turns into more power.
ARPs w/OEM Gaskets
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
post #5 of 61 Old 06-04-2013, 04:11 AM
You went from a street tune to a race tune. I would hope you saw a difference.
Once we get my final turbo in place, I will probably be switching to Tony's tunes too. I've heard nothing but good about him. I love my SRL+, but Matt doesn't have the tuning figured out yet for MTW's turbos.
WLDHRSE is offline
post #6 of 61 Old 06-04-2013, 09:12 AM
My stage 1 with 175/stock would ride out with srl xxx. Matt the only tuning I will tryed others and Matt hands down the best
Ryan
2003 2wd 6.0 egr gone, blue spring, extremeX
305/50/20 nitto 420s (lowered in the rear)
205/100 bw66
Boost got you loose
13.4 with a 1.9 60ft spinning anit winning
YOUR CUMMINS MIGHT BE FAST BUT YOUR GIRLFRIEND LIKES MY SLOW POWERSTROKE
my youtube channel mostly 6.0 videos
risco is offline
post #7 of 61 Old 06-04-2013, 10:10 AM
MrOneEyedBoh's Avatar
Quoted: 13 Post(s)
Feedback Score: 11 reviews
What kind of boost are you seeing?
MrOneEyedBoh is offline
post #8 of 61 Old 06-04-2013, 10:13 AM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
You DEFINITELY have a problem if there is a haze with a stage 2 and stock injectors.
l BRYAN l
COMPIGNTECH .COM
Look us up on Facebook
COMPRESSION IGNITION TECHNOLOGIES
l 2005 l Ford F250 l FTX l
[A Few Odds-N-Ends]
Tuscany is offline
post #9 of 61 Old 06-04-2013, 11:11 AM
Is that tuned for a stock turbo?
WLDHRSE is offline
post #10 of 61 Old 06-04-2013, 12:34 PM
This. My stage 1 with 175 injectors only has a little haze @ wot.
