Is there a step by step guide on installing a MTW billet wheel? - Ford Powerstroke Diesel Forum
post #1 of 9 Old 06-03-2013, 05:59 AM Thread Starter
My old man is about to put the billet wheel on my 03 turbo(him and the truck are 200 miles away) and he was wondering what torque numbers to use, lock-tight? anti seize? Tips etc for the turbo.
FATHERFORD is offline
post #2 of 9 Old 06-03-2013, 06:01 AM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
Feedback Score: 10 reviews
MTW Custom Billet Wheel/Tweaked Stage 1 Review!! Pic and Vid Heavy!!
l BRYAN l
COMPIGNTECH .COM
Look us up on Facebook
COMPRESSION IGNITION TECHNOLOGIES
l 2005 l Ford F250 l FTX l
[A Few Odds-N-Ends]
Tuscany is offline
post #3 of 9 Old 06-03-2013, 06:14 AM Thread Starter
So you didn't re-torque anything down? No anti-seize or anything?
This goes against anything I ever done rebuilding previous turbos.
post #4 of 9 Old 06-03-2013, 06:16 AM
BACKYARDIGAN
windrunner408's Avatar
Quoted: 4 Post(s)
OP, text me at 810-869-7782 if you need help but in all honesty it is pretty straight forward. No loctite, only use the Hi-Temp Anti-sieze on the vane area, and there really isn't a torque spec for these wheels. They are left hand thread so they will actually tighten themselves onto the shaft vice loosen as the turbo spins. I just tighten the wheel until I feel it (no kidding) stop tightening. It is weird I know but you can feel the wheel tightening slowly and then it will be like you hit a stop and that's it.
Nate
2006 F350 (BACKYARDIGAN) - 67mm Turbo, 215/85 injectors, WPE intake manifold, NB/Warren Trans, and more stuff that I don't care to mention....
2006 F250 (LITTLE DURTY) - WPE Manifold, Up-pipes, EGR delete kit, and Tuned By ME
BULLET PROOF DIESEL 1-888-967-6653
KC TUROS - Not just a modified Powermax...
WINDRUNNER PERFORMANCE ENGINEERING
windrunner408 is offline
post #5 of 9 Old 06-03-2013, 06:20 AM Thread Starter
Well that is what I will tell him then. Him and I still can't get over the fact we don't have to balance the shaft/wheels changing these out. We messed with a lot of gas turbo applications, and this just seems way to simple.
03 F-250 Lariat FX4
MTW 03 turbo billet wheel
PHP FICM Atlas 40
GearHead SRL
Strokers Unlimited Coated Up-pipes
3.5" dowpipe/4" exhaust
AFE Stage 2 Pro Dry CAI
6.4 Banjo
Blue Spring
EGR Delete
Edge CS
Coolant by-pass filter
Oil by-pass filter
post #6 of 9 Old 06-03-2013, 03:46 PM
N.S.D.Q.
HeavyAssault's Avatar
Quoted: 108 Post(s)
Feedback Score: 3 reviews
While it's not required the OEM compressor and turbine are balanced as a pair.
Officially The Biggest Midget In The Game
(In support of Zmann's request)
HeavyAssault is offline
post #7 of 9 Old 06-03-2013, 05:23 PM
When I got my Batmo I also got a note that said to tight to 200in/lbs Which I did and I also did the same with my MTW wheel. now this was for Pmax wheels so I don't know if it's the same.
2003 F350 6.0L KR CCLB DRW 4x4 auto - bone stock
Edge insight, EAS EGT, turbo timer
Strategys, DAX0-1;TEC0-7
Ford Pilot injection
2005 F250 6.0L XLT CCLB 4x4 auto
Strategys, UPV1;URV0;CYH0-7
PowerMax-KTS 11 blade SP Billet
ARP studs, BPD EGR cooler, 04 uppipe
Banks intercooler system, Airaid Dropin
4" turbo back Magnaflow exhaust w/4" DP
SCT 3015
ID custom tunes
ID Pilot-Injection
ID FICM tune
U235a4 is offline
post #8 of 9 Old 06-03-2013, 08:08 PM
I torqued mine down to 10ft lbs. no issues
Late 04 f350 lariat.
bpd
marty's regulated return
205/75 injects from holder's
WPE stage 3 ported intake
64.5 borg warner fmw ,compounds in the works now! Comp turbo set up
Warren comp trans
all the typical mods
Big thanks to Dale! The man is a true professional
04cr450 is online now
post #9 of 9 Old 06-03-2013, 09:54 PM
nordstrom's Avatar
Quoted: 2 Post(s)
Get yourself one of these kits makes life easier. Has new O-rings, bolts and gaskets cost around 40 bucks
Name:	2013-06-03 21.40.08.jpg
2006 F350, Holders Ported Intake, ARP Studs, Factory Turbo w/MTW Billet Wheel, Edge Insight, Atlas 40 FICM Tune, Stock Sticks, BPD Ficm 53V, BPD EGR Cooler, BPD Remote Oil Cooler W/ cold weather pkg, BPD Water Pump, Blue Spring Upgrade, S&B Cold Air Intake, CCV Relocate, 64K miles and counting
nordstrom is offline
