DTCs with PTP shift solenoid? - Ford Powerstroke Diesel Forum
post #1 of 28 Old 06-01-2013, 01:35 PM Thread Starter
Fox Hunt's Avatar
Quoted: 30 Post(s)
So I changed my ATF today and installed my PTP shift solenoid. Get everything buttoned up and it throws P0768 and P0765, both relate to the solenoid, take it back and swap back the stock on and it works fine. I had the electrical plug at the 5 o'clock position was that my problem? I've hear both the 5 and 7 position. Also i forgot to put the c clip back on my stock solenoid and then remember to, and when the clip was off it still threw codes but with the clip on it was fine, im assuming this clip is a ground? All the other solenoids the c clips are on the bottom facing up, if i reinstall the PTP one does it matter the position of the c clip? should it be up and down or up and down in correlation to the new solenoid since it is tilted?
2006 F-350 CCSB Lariat
MBRP 4" Exhaust, ARPs, Barder Stage 2 turbo, S&B CAI, TSD SPD, Warren Competition transmission, Edge CTS, Coolant Filter, High Idle Mod, CCV Mod, Zoodad, Newton Leveling kit, Fuel Mavericks 20x9 , Pioneer DVD head-unit, JL Stealthbox and JL Slash 500/1v2 amp
Future Mods:
Injectors and Driven Diesel RR
-Alex
Fox Hunt is offline
post #2 of 28 Old 06-01-2013, 05:45 PM
snafu!'s Avatar
Subscribed
Ordered a DD solenoid from Gary waiting for it to arrive. From what I have read the orientation doesn't make a difference.
Cameron
2006 F250 Lariat CCSB
Comp Turbo 64/88 compounds
Warren 285/100
ODAWG ported intake
R&R rods, mahle pistons, stage 2 colt cam
Built Trans
Water/Meth
snafu! is offline
post #3 of 28 Old 06-02-2013, 07:10 AM
strokin6L's Avatar
Quoted: 4 Post(s)
The one from PTP must be the gogo DD solenoid. It will either be in the 5 or 7 o'clock position when installed. Ive been running one for a few years. The c-clip doesn't ground anything. It keeps the solenoid in place so it doesn't slide out of the solenoid body.
2004 F-350 SC 4x4, XLT, 4" dual Magnaflow, AFE intake, No Limit piping, spearco intercooler, water injection, ARP studs, hypemax o-ringed heads, SCT tuned by Innovative Diesel, tuned FICM, Hellman's sump, FASS, Fuelab, regulated return, 190/75 injectors, KC/MTW 68 w/.72ar, suncoast trans w/billet input, edge insight CS with dakota digital gauges, amsoil by-pass, BD exhaust manifolds
strokin6L is offline
post #4 of 28 Old 06-02-2013, 07:12 AM
Slacker
Evil Eye's Avatar
Quoted: 219 Post(s)
Feedback Score: 4 reviews
I'm not sure since I haven't run the PTP solenoid. Didn't have any problems with the solenoid I bought from Doug; no codes or anything like that, but it was oriented differently like you mentioned.
Shawn Carlson
Proud Navy Vet
2005 F250, CCSB, 6.0 PSD, FX4 (The Sweet Unit is white)
2008 F350, CCLB, 6.4 PSD (Brad-the wife's truck is black)
Engine Mods:
Fluidampr
CCV Reroute (Reinstated)
4" MBRP Exhaust
MTW Stage 1 Turbo
Bulletproof 53V FICM
BulletProof EGR Cooler
BulletProof Water Pump
Riff Raff Intercooler Boots
Gogo Diesel Direct Drive Solenoid
BulletProof All-Aluminum Radiator
BulletProof All-Aluminum Intercooler
BulletProof Oil Cooler System w/ Bypass Filter
SCT w/ Custom Tunes (TSD, DJ's, Innovative, Gearhead, QuickTricks)
Exterior Mods:
Bilstein 5100 Shocks
Icon Adjustable Trac Bar
Firestone RideRite Air Bags
BDS Dual Steering Stabilizer
Aluminum Finned Differential Cover
Reese 16k Manual Slider 5th Wheel Hitch
Icon 2.5" Leveling Kit w/ F-350 rear blocks
20" BMF Novakanes wrapped in 33" Nitto Terra Grapplers
Evil Eye is offline
post #5 of 28 Old 06-02-2013, 09:18 AM
onebadcoastie's Avatar
Quoted: 10 Post(s)
Shack
2016 F-350 CC Dually
2005 F250 CC FX4….SOLD
onebadcoastie is offline
post #6 of 28 Old 06-02-2013, 09:41 AM
colonel angus's Avatar
Quoted: 2 Post(s)
I installed this Sol. and didn't have any issues, my guess is you've got something awry if you can forget something as important as the retaining clip something else isn;t connected or isn't in place correctly.
Denny
2005 CC SB 147K
MTW MaDmAx 68mm VGT
Warren Diesel 175/75's Super Spools N Drew's Tunes
VXCF9CA TQCI1NB
SCT A101706100004F6C
VIN FTSW21P65EB08535
ARP's - MBRP T-Back Kitty Del.
ICON 4.5" + 2" Spacer
Mickey T's Baja ATZ P3 37's
METHOD Racing Wheels 20x
ScanGauge II / RedHead Box
Snow Perf. Stg. II W/ Banks Intercooler
Bulletproof EGR Del. & External Filter
ELC Coolant & Sin. Coolant Filter
AMP Steps & ARE Cover W/ Bed Slide
colonel angus is offline
post #7 of 28 Old 06-02-2013, 10:07 AM Thread Starter
Fox Hunt's Avatar
Quoted: 30 Post(s)
Denny
Thanks? Didn't ask about my competence. As for the php one, it was installed just as I've read everyone says to. After the having to drop the pan again and running outta time, I forgot sorry. It happens to some people. But once the clip was one, more problems. I guess I'll try it again when I have time and put it in the 7 o'clock position.
Sent from AutoGuide.com App
Future Mods:
-Alex
Fox Hunt is offline
post #8 of 28 Old 06-02-2013, 10:28 AM
BACKYARDIGAN
windrunner408's Avatar
Quoted: 4 Post(s)
I believe the PTP one is the gogo solenoid as that was where I got mine from. I never got around to installing it and sold it.
Gary's solenoid that he sell is not like a gogo solenoid. I believe the gogo/ptp one is a modified EPC solenoid where Gary's is actually a modified DD solenoid and orientates just like the OE DD solenoid does in the 6 o'clock position.
Nate
2006 F350 (BACKYARDIGAN) - 67mm Turbo, 215/85 injectors, WPE intake manifold, NB/Warren Trans, and more stuff that I don't care to mention....
2006 F250 (LITTLE DURTY) - WPE Manifold, Up-pipes, EGR delete kit, and Tuned By ME
BULLET PROOF DIESEL 1-888-967-6653
KC TUROS - Not just a modified Powermax...
WINDRUNNER PERFORMANCE ENGINEERING
windrunner408 is offline
post #9 of 28 Old 06-02-2013, 11:24 AM
Quoted: 10 Post(s)
I'm curious about the modded version and non-modded version and this whole "clocking" of the solenoid.
Shack
post #10 of 28 Old 06-02-2013, 04:46 PM
RIP Mitch ! We miss you
PGreenSVT's Avatar
Feedback Score: 3 reviews
PTP no longer does business with that scum sucking thief Doug Gilbert aka Mr. Gogo Diesel. Their Solenoids are modified in house now.
You might just have gotten a bad solenoid. It happens.
RIP Mitch
the Org crew
PGreenSVT is offline
