Cut open my coolant filter - Ford Powerstroke Diesel Forum
post #1 of 10 Old 06-01-2013, 10:42 AM Thread Starter
usnavyad's Avatar
Feedback Score: 3 reviews
Well everyone after having my coolant filter on like 2 k miles I seen my deltas rising so I was like ok let's change my coolant filter and cut it open. Here is what I found
Guess these things work huh lol
04 harley davidson f-250 arp headstuds oem gaskets,sb intake,edge cts egt probe,sct sf3 idp tuned/ php tuned,blue spring,zerex coolant swap,mbrp 5 inch xdp 6 inch tip,sinister egr cooler,new oem oil cooler,atlas 40 ficm,Painted cac tubes 7.3l wire loom,Diesel site coolant filter
GPDA's other shawn
usnavyad is offline
post #2 of 10 Old 06-01-2013, 10:54 AM
ZMANN's Avatar
Quoted: 1900 Post(s)
thats about normal
We Miss you Ronnie
6.0 flush pdf
ZMANN is offline
post #3 of 10 Old 06-01-2013, 10:55 AM Thread Starter
usnavyad's Avatar
Lmao I can't believe how much was In there they should come stock with a coolant filter
GPDA's other shawn
usnavyad is offline
post #4 of 10 Old 06-02-2013, 01:43 PM
legionxxii's Avatar
That's not bad I've seen some with filters clogged with gunk
2006 Ford F250 King Ranch CCSB Stock for now
Sold 2003 Ford F250 Fx4 CCSB 4" Turbo Back Straight Pipe With 6" Tip Egr Delete 6.4 Banjo Bolts Blue Fuel Spring Upgrade Cat ELC Coolant Coolant Filter Edge CTS SCT With IDP Tuning PHP FICM Tuner Zoodad Mod Track Time: 13.747
US ARMY 13F
legionxxii is offline
post #5 of 10 Old 06-02-2013, 05:26 PM
colonel angus's Avatar
Quoted: 2 Post(s)
My first cleaning resulted in an 1/8" paste / grit in a 5 gal bucket, filter was almost half full.
D
2005 CC SB 147K
MTW MaDmAx 68mm VGT
Warren Diesel 175/75's Super Spools N Drew's Tunes
VXCF9CA TQCI1NB
SCT A101706100004F6C
VIN FTSW21P65EB08535
ARP's - MBRP T-Back Kitty Del.
ICON 4.5" + 2" Spacer
Mickey T's Baja ATZ P3 37's
METHOD Racing Wheels 20x
ScanGauge II / RedHead Box
Snow Perf. Stg. II W/ Banks Intercooler
Bulletproof EGR Del. & External Filter
ELC Coolant & Sin. Coolant Filter
AMP Steps & ARE Cover W/ Bed Slide
colonel angus is offline
post #6 of 10 Old 06-03-2013, 05:19 AM
MyTractorsSexy's Avatar
Quoted: 7 Post(s)
you did it rather early at 2k miles i did mine in the order of 5k 10k 15k 1 every 25k but the filters are cheap so why not change it whenever you want lol but you still had some good room in there
Mild build 07 F250-SOLD
2011 Black CC SB Lariat F250, 2015 Retrofit, MPD IC Piping, H&S Mini Maxx custom tuned, 5"Flo-pro Exhaust, Sininster Egr Delete, Recon Lighting, No Limit S2 Intake, Tinted, BDS 8" 4-Link Lift w/ Fox Shocks & Dual Steering Stabilizer, 4.10 Yukon's with electric lockers, 37/13.50/22 Toyo MT, 2-Piece Fuel Maverick 22x12 Wheels, PTM Grille Surround, T REX X-Metal Grille, LED heads and fogs, kenwood double din, 4 hertz 210W door speakers 2 JL TW3 10s kenwood amps.
MyTractorsSexy is offline
post #7 of 10 Old 06-03-2013, 05:26 AM
ZMANN's Avatar
exactly I could probably go over a year but sometimes I just get curious
and since it's a bypass (most styles) and fluid would rather take the path of least resistance
any blockage could result in less filtration
so for 13 bucks I probably do mine 3 - 4 times a year
I also cut open the filter media and rinse it into a bucket to see whats trapped
We Miss you Ronnie
6.0 flush pdf
ZMANN is offline
post #8 of 10 Old 06-03-2013, 06:20 AM
Quoted: 7 Post(s)
i never even cut mine open im honestly to lazy i know it traps tons of stuff cause if i flip it grit comes spilling out so i know it does its job.
post #9 of 10 Old 06-03-2013, 02:40 PM Thread Starter
usnavyad's Avatar
I'm anal and wanted to see first hand lol
GPDA's other shawn
usnavyad is offline
post #10 of 10 Old 06-03-2013, 03:03 PM
t-ray-4ray's Avatar
Quoted: 94 Post(s)
Attachment 120034i know this is a 6.0 thread but this came off my 7.3 after 1000 miles after a flush but the second filter was spotless after 3,000 miles
Sent from AutoGuide.com App
2000 f-350 4x4 extended cab, went from a flatbed work truck to what you see now, all done by me. Early 99 engine, billet low stall converter, rebuilt trans, all new uvch, new belt tensioners and idler pulley, rebuilt injectors, all new icp, idm, cps, hutch mod, k&n intake, white valve covers, wicked wheel, 5 inch exhaust, php hydra chip 15pos, 8" superlift, 20 inch black and machined rims, 2" billet spacers, 37/13.50r20 toyo open country tires, rough country dual stabilizer, 05 front end with 10k hid lights, amber led cab lights, 09 ford van bucket seats, 2010 f150 center console, b&m ratchet shifter, aero force scan gauge, b&m trans cooler used as a fuel cooler,
t-ray-4ray is offline
