Zoodad Mod = More Smoke? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 06-01-2013, 11:14 AM Thread Starter
mikegoslin09's Avatar
Hey y'all, new to the forum although I have done a lot of reading on here as a guest. I just did the Zoodad mod this morning, not expecting much as it is just drilling a hole in front of the intake, but I just ran to the store and something struck me as odd.
I took precautions to block off the intake ahead of time so I didn't get any dust in there and I even vacuumed out any remaining particles after the project. I put a screen in front to block out any leaves, big bugs, etc. just as your suggestions have mentioned, but as I was driving I was getting some black smoke out of the stacks.
Not "Rollin' Coal" by any means, but a decent black puff when leaving stop signs and lights and also when I get on it a but my truck never smoked before. Maybe a hair here and there but nothing compared to now.
Should this be happening? Thank you.
2004 F350 6.0L Powerstroke FX4
72,000 miles and climbing
4" MBRP turbo back to 6" stack
SCT SC3, tunes from Eric @ Innovative Diesel
Edge Insight CS
GlowShift Boost, Fuel Psi, 2400* EGT gauges
Blue Spring Mod
Zoodad Mod
Venom Wheel 2" spacers
Still running Ford Gold with great deltas, good coolant pressure. Healthy truck.
mikegoslin09 is offline
post #2 of 6 Old 06-01-2013, 11:52 AM
GregsSD's Avatar
Quoted: 15 Post(s)
Garage
There is no way that the Zoodad mod can cause more smoke!
The only way that it could be related to the Zoodad mod would be if you caused something to partially restrict the air getting into the filter, but it sounds like you made sure that wouldn't happen.
I would suggest to double check your filter itself to make sure it is clear.
2005 F-250 CC/SB 4x4 medium wedgewood blue
5" lift, 5" Donahoe rear springs, 35x13.50 MTZ's, 18x12 Fuel Hostage wheels, 4.30 gears, Banks 4" exhaust, Airraid intake, SCT from Innovative, ARP headstuds, Bulletproof ficm, Scangauge II, Randy Ellis Design lightbar, Street Scene flares, Harpoon mod, Zoodad mod, LED 2010 taillights, Switchback LED front turn signals
GregsSD is offline
post #3 of 6 Old 06-01-2013, 11:57 AM
ZMANN's Avatar
Quoted: 1456 Post(s)
agreed
no way it affected anything
and the OEM filter can hold over 4lbs of dirt before the filter minder sets
We Miss you Ronnie
ZMANN is online now
post #4 of 6 Old 06-01-2013, 11:57 AM Thread Starter
I double checked it and it has nothing more than any normal filter would. I shook it out and vacuumed what I could carefully after the ride. I am still running OEM intake but will definatly keep an eye on it. Thought I would ask just for piece of mind.
Edge Insight CS
Blue Spring Mod
Zoodad Mod
post #5 of 6 Old 06-01-2013, 07:54 PM
colonel angus's Avatar
Quoted: 2 Post(s)
Did you remember to remove the rag you put in front of the turbo?
Not making fun of you as I didn't remember it either.
D
2005 CC SB 147K
MTW MaDmAx 68mm VGT
Warren Diesel 175/75's Super Spools N Drew's Tunes
VXCF9CA TQCI1NB
SCT A101706100004F6C
VIN FTSW21P65EB08535
ARP's - MBRP T-Back Kitty Del.
ICON 4.5" + 2" Spacer
Mickey T's Baja ATZ P3 37's
METHOD Racing Wheels 20x
ScanGauge II / RedHead Box
Snow Perf. Stg. II W/ Banks Intercooler
Bulletproof EGR Del. & External Filter
ELC Coolant & Sin. Coolant Filter
AMP Steps & ARE Cover W/ Bed Slide
colonel angus is offline
post #6 of 6 Old 06-01-2013, 07:56 PM Thread Starter
I didn't put a rag in front of the turbo. I taped off the intake entrance and then placed a block off wood to catch the hole saw bit going through it. I will just keep an eye on it.
Edge Insight CS
Blue Spring Mod
Zoodad Mod
