Injectors? - Ford Powerstroke Diesel Forum
post #1 of 101 Old 06-01-2013, 05:46 AM Thread Starter
6.boom's Avatar
Injectors?
I just had a complete engine rebuild on my truck, virtually one of the only things they did not replace was the injectors. I now have ARP studs an the whole nine yards. I plan on upgrading my turbo eventually to a hybrid or powermax, along with upgrading my fuel system.
My injectors are sticking and need replaced sometime in the near future. I want to upgrade them for better fuel econ and performance. I don't want to go too big because really, I don't need to be pushing 600hp. But I would like some sort of performance boost. What is the next step above stock or what is best for fuel econ?
I've got 99 problems and my 6.0L is all of them.
Want to creep? Instagram: lynntaraa
6.boom is offline
post #2 of 101 Old 06-01-2013, 06:02 AM
JGman141's Avatar
155s are the next step up and if you keep the stock nozzle it will help keep your fuel economy and give you alittle boost in power. Also I would go with warren diesel for injectors.
2004 6.0 ccsb Warren 430/150 hybrids, Warren Comp Trans, Warren Dual Hpop, Billet S475 w/race cover, Marty's A1000 Fuel System, Colt stage 2 and all the other supporting stuff
JGman141 is offline
post #3 of 101 Old 06-01-2013, 06:25 AM Thread Starter
6.boom's Avatar
Would it be bad to go up to 175cc?
6.boom is offline
post #4 of 101 Old 06-01-2013, 06:34 AM
JGman141's Avatar
No you can always have fuel pulled if you need to and if I were you I would go with the 175/stock or 30. That injector will work well with the hybrid turbo
JGman141 is offline
post #5 of 101 Old 06-01-2013, 08:06 AM
the chad's Avatar
I would do a 175/30 or something around that, be a nice dd setup.
Chad
07 F250
4'' MBRP to 7'' FTE Miter
ELC w/ Sinister Coolant filter
ARP's with OEM
Edge CS and Trans, Boost, FP on the pillar
Voltmeter in dash
Banjo's
Looney
Cal-Tracs
20x10 Monsters wrapped in 305 420s
RCD Egr Delete
Warren 190/75
Dozers RR
MTW Stage 2
557 hp/1206 ft/lbs
Big thanks to JJ @ Dozers And Adrian at MTW
the chad is offline
post #6 of 101 Old 06-01-2013, 12:34 PM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
Feedback Score: 10 reviews
You can run 175's with a stock charger and stock fuel system just fine. Just need to have some fuel pulled with the stock charger because your temps will get HOT, quick, fast and in a hurry. I have pegged over 2000 EGT's with my old 175/stock injectors.
l BRYAN l
COMPIGNTECH .COM
Look us up on Facebook
COMPRESSION IGNITION TECHNOLOGIES
l 2005 l Ford F250 l FTX l
[A Few Odds-N-Ends]
Tuscany is offline
post #7 of 101 Old 06-01-2013, 12:52 PM
peixinho's Avatar
Quoted: 196 Post(s)
I vote 175 with stock nozzles...
I just had mine done. On a race tune they run fast and hot, but on my tow tune or stock tune you don't even notice they are in there. Best of both worlds
KC Turbos
Warren Diesel Dealer
My Current Build Thread
Current Setup 190/30 and KC 64mm Stage 2 turbo
peixinho is offline
post #8 of 101 Old 06-01-2013, 01:34 PM Thread Starter
6.boom's Avatar
Please forgive my ignorance, pull fuel?
6.boom is offline
post #9 of 101 Old 06-01-2013, 01:37 PM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
Yeah in your custom tune. You would need to have the file writer pull fuel throughout the RPM range so that this doesn't happen.
l BRYAN l
COMPIGNTECH .COM
[A Few Odds-N-Ends]
Tuscany is offline
post #10 of 101 Old 06-01-2013, 01:47 PM Thread Starter
6.boom's Avatar
ok thanks!
6.boom is offline
