03 Turbo Swap Discussion
My truck is an Oct.2003 build date, but is a 2004 truck.
It has the 7 fins on the compressor impeller. To be a 2003 should it have 10 fins on the exhaust side? Also, has anyone removed the silencer ring at the front of the turbo? I heard it will let you flow more air and has more whistle |
Anyone????
It sounds like you have an 03 turbo. Most people just throw them on and straight pipe the truck to get a good amount of whistle. Although I have heard of some removing the SR. I hope this helps.
Dunno about the silencer ring...but all the turbos have the 7 blade on the intake side, it is the 10 on the exhaust that makes the determination. And some 04 early builds do have the 03 turbo, but I don't remember the cut off on the build dates.
I just bought an 03 f-350 with an AEM intak and a Magnaflow 4 inch exhaust from the turbo back and the whistle is awsome. never get tired of listening to it!
Thanks pain train & eric.
I am having to replace my second turbo. something ate 6 of the 7 fins and just want to make sure they put the exact same type of turbo back on my truck. |
OUCH! 6 of the 7 blades? Man, something lit your turbo up!
. I would be upset if they gave me a different turbo as well.
This is the puzzler. It has had a high whine for the last 4 ro 5 months, but I just thought it was the regulated return system that I just had installed at the same time my H-11 head studs were put in. (ignorance on part I guess)
Well, Thursday I was starting to do NCHornet's CCV mod and when I took off the boot that connects to the turbo, below is what I saw. I have had no boost loss, I can hit 32 to 34 all day long. Just have no idea what happened.
Ewwww! That's pretty ugly there Bama!
A problem I just thought of is, I don't know if they are still producing the 03 10 vanes. To switch from late year to 03 all of takes is a pedestal swap, hope they don't do the same thing and "upgrade" you to a newer turbo/pedestal setup.![]()
