SCT coming tomorrow - Ford Powerstroke Diesel Forum
Old 03-12-2008, 05:20 PM
Send a message via AIM to pistolpete837
SCT coming tomorrow
ok so i am getting my XCAL3 from DJ's tomorrow, i remember reading somewhere that after loading the tunes to drive normal for a while to let the tranny learn the tune. is this true i cant remember exactly what the thread said?
by the way DJ's was great cant wait to go looney
Thanks
Peter
Old 03-12-2008, 05:28 PM
i am not sure about that, i have not seen or read that before.
Old 03-13-2008, 02:57 AM
Gun Nut
Congrats! You're gonna LOVE it.
Yes they say you need to drive it a bit for the tranny to learn it - I think they say around 20 miles give or take.
Old 03-13-2008, 03:06 AM
Rob Rob is offline
yes drive it normal for a bit. i usually let it go through the full range of gears several times before i get on it. also, make sure your tranny is at temp before you go out and get on it too hard.
Old 03-13-2008, 03:48 AM
thanks for the info. is this every time i change tunes or just the first time?
Old 03-13-2008, 04:13 AM
It depends on what tunes you are running but yes you should give a few cycles through the gears every time you swap tunes. Some tuners do better with the tranny than others and their "relearn" time is little to none and others take a bit to settle in.
I've also found that with my stop and go daily commute at low speeds that the tranny will start to get lazy in time. I assume that it learns that grandpa style and doesn't want to run hard. When that happens I reload the tune and all is well again.
Old 03-13-2008, 05:37 AM
You would want to give the tranny a chance to relearn anytime you change tunes. Drive normal, don't just poke around but don't drop the hammer either. Also, it learns every drive cycle so park and turn it off for a second and restart it and continue to drive. After a few miles go ahead and bang on it if you want too!
I agree w/ 720Deere that tunes do seem to make your tranny kinda' soft or sloppy after being loaded for a while so I would reinstall it periodically for another relearn for that crisp shift.
Stay Tuned
Amp
Old 03-13-2008, 05:43 AM
KVFD
You will love that sct!!!
