Swapping Tunes Daily? - Ford Powerstroke Diesel Forum
post #1 of 14 Old 05-31-2013, 08:24 AM Thread Starter
5fifty's Avatar
Quick Question...... I know it is probably a newbie question, but I figured i'd ask for my own knowledge.
Is there any problem with swapping between tunes on a day to day basis?
I find myself lately changing between my heavy tow and street tune often. Sometimes I do it daily or every other day.
Runs good on both, but my street tune is deff not up to the task of towing and my tow tune is smokey if I am heavy footing it around town.
Just trying to see if there are any known issues with doing this on a regular basis.
Thanks in advance.....
2005 F-550 4x4 22.5's
Kelderman Air Ride
Bulletproof Diesel Remote Oil Cooler W/F550 Cooler
Bulletproof Diesel Billet Water Pump
Bulletproof Diesel Radiator
Dieselsite Wicked Wheel, Dieselsite Coolant Filter Kit
Warren Diesel 155/30, Bluespring Mod, 6.4 Banjo,
Updated STC, Turbo Feed and Drain Tubes,
PMM EGR Delete
SCT Tuner, Edge Insight w/EGT, Fuel and Oil Pressure
Tuned By MATT @ Gearhead Automotive Performance
5fifty is offline
post #2 of 14 Old 05-31-2013, 08:56 AM
Powerstroke Techie
JUGERNAUT's Avatar
Quoted: 3 Post(s)
Feedback Score: 13 reviews
Very good question but I believe if done on a daily basses I would make sure you have a backed up stock file on your pc.
2001 to 2015 SENIOR MASTER TECHNICIAN
BEEN WITH FORD 27 YEARS:
PROUD NAVY VET= ANTI SUBMARINE WARFARE
A/C ASW A/W WINGS
2003 F250 AND I HATE IT. IT ROBS ME BEFORE I GET TO BANK!
JUGERNAUT is offline
post #3 of 14 Old 05-31-2013, 10:29 AM
Couldn't you get someone to write a multipurpose tune?
harrisford is offline
post #4 of 14 Old 05-31-2013, 10:51 AM
twoicebergs's Avatar
Quoted: 46 Post(s)
I have done more than 4 in a day for testing a number of times. I usually don't see any issues, except for the occasional shifting issues, but only on very OLD tunes and usually only until all the gears have been run through once. However, I do know at some point there will be a glitch that will require a master reboot or a stock reload to bring it back. It really becomes more of a PITA to have to keep switching with the potential risk that it entails.
My best economy tune is not my Extreme tune, but a mid tune with advance timing and boost that is just high enough to clean up my injectors. I guess I could get a tune reworked to be only extreme with the APS at 75% or greater. The same could be said for towing and performance, recognizing the requirement to not be too tempted to light the burners.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #5 of 14 Old 05-31-2013, 10:52 AM
Chatham036's Avatar
Quoted: 136 Post(s)
I run a performance file and do not deviate even when towing. I just watch my EGTs
Comments or opinions expressed by me do not necessarily represent the views of PHP, its management, nor its employees. PHP is not responsible for, and disclaims any and all liability for the content of comments written by me.
Chatham036 is offline
post #6 of 14 Old 05-31-2013, 01:02 PM
Powerstroke Techie
JUGERNAUT's Avatar
Quoted: 3 Post(s)
What you said has happened to me and i had to reformat sct device and reprogram my truck with my ids so i understand what your sayin two!
A/C ASW A/W WINGS
post #7 of 14 Old 05-31-2013, 01:31 PM
majek5's Avatar
Isn't the problem towing with a hot tune the ICP and other issues besides EGT?
2006 F350 CCLB KR FX4
stock...
majek5 is offline
post #8 of 14 Old 05-31-2013, 02:28 PM
N.S.D.Q.
HeavyAssault's Avatar
Quoted: 116 Post(s)
Feedback Score: 3 reviews
For day to day the PCM will be trying write the tables. If you keep swapping the parameters around it will just keep writing the tables with no conclusion.
I for one find it takes upwards of two weeks for tuning to settle in the PCM. I tow a boat so I keep an eye on the EGTs with my street file. I have a heavy tow tune loaded as stock on my PCM when needed.
I think you need some new tuning of just learn to stick with one file for your daily needs.
Officially The Biggest Midget In The Game
(In support of Zmann's request)
HeavyAssault is offline
post #9 of 14 Old 05-31-2013, 07:49 PM
turbotibbo's Avatar
I feel the same way
2006 ford f350 xlt cclb
blue spring mod
6.4 banjo bolts
gogo direct cluth solenoid
Insight cts with pyro
str8 pipe , fuel pressure gauge
air raid cold air
zoodad mod
high idle mod
sinister coolant filter kit ec-1 rated
58 volt ficm
powermax turbo , sinister y pipe
egr delete
sct x3 with running looney wild , spd early lock up
arp studs , updated stc fitting ,stand pipes,
dummy plugs , new oem injectors
turbotibbo is offline
post #10 of 14 Old 06-03-2013, 07:55 AM Thread Starter
5fifty's Avatar
Thanks for the reply. I have my stock file on my laptop and my PC.Guess I could also save it to my phone for a worst case scenario.
Kelderman Air Ride
PMM EGR Delete
5fifty is offline
