What fuel setup - Ford Powerstroke Diesel Forum
post #1 of 28 Old 05-31-2013, 08:31 AM Thread Starter
Stumppy's Avatar
What fuel setup
Ive decided on getting 155 30 injectors from warrens. Im debating upgrading my fuel system as well while I am at it. I know the AD2 is pretty much garbage but what about FASS? What fuel pumps are everyone running out there? Should I do a regulated returm and a sump also? Any help would be great this is a area I do not have very much knowledge on. So school me if you will.
2004 CC SB 6.0
4 Inch Turbo back Exhaust
S&B Intake
Sct with Vivians looney wild tune.
Egr Delete
Arp Head studs and oem gaskets.
Stumppy is offline
post #2 of 28 Old 05-31-2013, 08:50 AM
Turbos = Witchcraft
TooMuch03's Avatar
Feedback Score: 3 reviews
For your 155s, I would do a regulated return and call it good. The stock pump can handle up to 190s without an issue.
2003 F250 6.0
Originally Posted by Tuscany View Post
Compounds FTW!!!
TooMuch03 is offline
post #3 of 28 Old 05-31-2013, 09:52 AM Thread Starter
Stumppy's Avatar
Should I do a sump with it or just call it good with the return kit?
2004 CC SB 6.0
S&B Intake
Egr Delete
Stumppy is offline
post #4 of 28 Old 05-31-2013, 10:02 AM
Powerstroke Techie
JUGERNAUT's Avatar
Quoted: 3 Post(s)
Feedback Score: 13 reviews
I did 3 155/30 set ups all running stock pump with blue spring just fine
2001 to 2015 SENIOR MASTER TECHNICIAN
BEEN WITH FORD 27 YEARS:
PROUD NAVY VET= ANTI SUBMARINE WARFARE
A/C ASW A/W WINGS
2003 F250 AND I HATE IT. IT ROBS ME BEFORE I GET TO BANK!
JUGERNAUT is offline
post #5 of 28 Old 05-31-2013, 10:07 AM Thread Starter
Stumppy's Avatar
That would be awesome that would save me 700 bucks. That might be the route I go.
2004 CC SB 6.0
S&B Intake
Egr Delete
Stumppy is offline
post #6 of 28 Old 05-31-2013, 10:22 AM
AD2 > FASS
Stock pump is fine. You could feed it with a 6.4 pump, just for a little cheap insurance.
WLDHRSE is offline
post #7 of 28 Old 05-31-2013, 10:28 AM
colonel angus's Avatar
Quoted: 2 Post(s)
What RR does the brain trust prefer?
D
2005 CC SB 147K
MTW MaDmAx 68mm VGT
Warren Diesel 175/75's Super Spools N Drew's Tunes
VXCF9CA TQCI1NB
SCT A101706100004F6C
VIN FTSW21P65EB08535
ARP's - MBRP T-Back Kitty Del.
ICON 4.5" + 2" Spacer
Mickey T's Baja ATZ P3 37's
METHOD Racing Wheels 20x
ScanGauge II / RedHead Box
Snow Perf. Stg. II W/ Banks Intercooler
Bulletproof EGR Del. & External Filter
ELC Coolant & Sin. Coolant Filter
AMP Steps & ARE Cover W/ Bed Slide
colonel angus is offline
post #8 of 28 Old 05-31-2013, 10:37 AM
Turbos = Witchcraft
TooMuch03's Avatar
I like Strictly Diesel. You can build your own for pretty cheap.
2003 F250 6.0
Compounds FTW!!!
post #9 of 28 Old 05-31-2013, 10:55 AM
BACKYARDIGAN
windrunner408's Avatar
Quoted: 4 Post(s)
I like building my own RR kit with Aeroquip fittings and braided stainless lines. I've ran the strictly kit and it does the job.
My personal opinion though is for 155/30s, I like an AD100 feeding the stock pump and that's it. You can do a sump but it isn't necessary. I don't even recommend the blue spring mod. I guess if you wanted to you could do 6.4 banjo bolts. I only recommend the Airdog because I like removing the air from the fuel. No I don't have any evidence that it does anything but make your truck run quieter, but I am glad I decided to run one on my truck. Got over a year of solid performance from it.
Nate
2006 F350 (BACKYARDIGAN) - 67mm Turbo, 215/85 injectors, WPE intake manifold, NB/Warren Trans, and more stuff that I don't care to mention....
2006 F250 (LITTLE DURTY) - WPE Manifold, Up-pipes, EGR delete kit, and Tuned By ME
BULLET PROOF DIESEL 1-888-967-6653
KC TUROS - Not just a modified Powermax...
WINDRUNNER PERFORMANCE ENGINEERING
windrunner408 is offline
post #10 of 28 Old 05-31-2013, 11:04 AM Thread Starter
Stumppy's Avatar
How much did your setup run you? I dont know much about a RR so Im not sure what parts I would even need to buy let alone put it all together.
2004 CC SB 6.0
S&B Intake
Egr Delete
Stumppy is offline
