Hard start - Ford Powerstroke Diesel Forum
post #1 of 4 Old 05-30-2013, 08:42 AM Thread Starter
Hard start
Hi I'm new to the hole diesel motor. So maby someone can help me out in the morning I go out to start my truck and it gives me a hard time I have to end up cranking it a cuple of times before it starts and then it will eather idle rough or stall out. Any ideas?
Dylanfritz is offline
post #2 of 4 Old 05-30-2013, 08:49 AM
F250SixOH's Avatar
Your FICM is probably the most likely culprit. First thing get a monitor such as the Edge Insight CS or CTS. A monitor is VITAL to keeping these trucks healthy.
F250SixOH is offline
post #3 of 4 Old 05-30-2013, 09:13 AM Thread Starter
Thanks ill check that and I will have to invest in a monitor.
post #4 of 4 Old 05-30-2013, 09:56 AM
Adamv7010's Avatar
Some kind of monitor is necessary
As stated...a failing ficm will cause this...
Also a hpo issues...bad or failing injectors...stiction...clogged fuel filters..and or other fuel related issues.
Adamv7010 is offline
Tags
f-250 6.0
