Atlas 40 review - Ford Powerstroke Diesel Forum
post #1 of 10 Old 05-30-2013, 03:24 AM Thread Starter
jetjock15's Avatar
Quoted: 113 Post(s)
Atlas 40 review
Got the Atlas 40 loaded with php's loaner programmer last night. Php is very easy to work with and I had the tuner in hand about 10 days after I placed order and that was over the three day weekend for shipping too - so that's pretty good. They include clear instructions and it took under 10 minutes. I drove a 10 mile loop of half highway half backroads to test before, with heavy/safe tune, and with an aggressive stud tow tune. I have all mech gauges so was able to view Ficm volts during driving on the monitor. It just bounced between 48.5 and 49.0 the entire time so that seems good.
I run the aggressive tow tune all the time, by request, Jody at DP tune took his aggressive 80HP studded and modified areas to add to give me a bit more performance and match 155s. I did this because I don't like the shifting or light switch effect of all the sheer performance tunes I've run. I like my truck to drive like stock- just more power - anyways. I will pull my trailer with this tune on shorter trips.
Before atlas 40 I would cruise this 7 mile section of highway with cruise on at 55. Steady EGT was 700 on slight downhill it would roll back to 600 and uphill 800 boost 5-7. Smoke only on initial stabs of throttle. Max EGTs full throttle run 1350. After Ficm same stretch boost same, stand EGT was 775 with climbs to 900 on grades. EGT was a constant 75 higher (as expected from php and fcimrepair websites). Smoke was a bit more on throttle stab, a very light haze on full throttle runs, and more black then I like when in OD kinda luggin them flooring it - smokes till downshifts than clears. Max full throttle run (same spot every time 0-85) EGT up to 1450. With these higher EGTs I wanted to try my "tow safe" tune, if EGTs were not lower I was thinking I would keep the programmer to be able to swap Ficm tunes, or just load php's economy tune.
So I loaded my heavy tow tune witch started with a 40hp heavy tow, modded for 155s. This is a 40hp tow safe tune for stock sticks than modified for injectors, turbo, mods. I was very pleased to see a huge drop in EGTs and smoke. Same section of fwy was now 600-625 to hold 55 with increases never over 700 on inclines. Boost was a tad lower at 4-6. Less but some smoke on throttle stab, cleared up on full throttle and only slight haze when in OD and I would floor it, until downshift cleared. Max EGT on full 0-85 run was 1225. This combo made me very happy and I believe this will be the sweet spot for towing my 17-23k trailer (depending on cargo). I think I am probably about 100Hp with this combo with 40HP tow tune (40HP) plus modded for injectors (30-40HP) then atlas 40 (20-30 HP) so that equal pretty realistic max sustained power level with my studs & big trailer IMO - only time will tell lol!.
I do have a performance tune that I have only ran a hand full of times. I did not load it for testing. With the 155s the EGTs were already high, I feel it would be excessive (IMO for my truck)with the Ficm tune- I will never again load the performance tune, which is not sayin much as I've only ran it maybe 300 miles in total ever.
The truck had the "lighter" feel on accelerations after the atlas 40 but nothing close to the differences observed when switching between ECM loads.
Bottom line - the atlas works as advertised. It increased EGTs about 75-100 across board, slight increase in smoke, and a bit better off the line performance. Php website has Dyno graphs and explains how this added power does not increase cylinder head pressure but does EGT. That is perfect for my needs. I will run my hotter tune for normal driving and short tows and load my heavy tow tune for the interstate trips and heavy loads.
I sent the programmer back as I see no need to keep. ($150 for the tune - $250 more if you want to keep tuner-$400)
Outside of the better off the line increase, which I can tell but it's not drastic - I observed much bigger power differences switching between my two tunes than I did when loading the atlas for what that's worth. It's no huge game changer but its increase in fuel is observable based on smoke, EGTs, and to a lesser degree - seat of pants. It was more hesitant to downshift unless being forced, which I really like. These are all exactly in-line with what php and fcimrepair claim- so overall I'm very happy.
I did not try the atlas 80 or Hercules tunes, although the tuner would allow me to. All in all it's a great $150 add for my towing setup but its no lightswitch like an ECM tune.
King/Deavers/37s/AF 22x12s/4:56/F/R Detroits/Road Armors/Warn12k/155/30s, MTW S1Billet/GoGo Manifold/Banks IC/NADP Heavy Hauler Trans/ORU Hydro-Steer/PHP tow Tune/BPD HD oil cooler/Oil & Coolant bypass/AMP steps/TransferFlow tank-toolbox
jetjock15 is offline
post #2 of 10 Old 05-30-2013, 03:52 AM
Thanks for the review! That should be helpful to a lot of people.
WLDHRSE is offline
post #3 of 10 Old 05-30-2013, 05:07 AM
kinnisoj's Avatar
Quoted: 2 Post(s)
Hopefully getting my ficm back today. I had the atlas 80 and I loved it. The truck, not so much. EGT's were high so Im now waiting on the atlas 40.
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #4 of 10 Old 05-30-2013, 06:19 AM
nice review.
2003 F350 6.0L KR CCLB DRW 4x4 auto - bone stock
Edge insight, EAS EGT, turbo timer
Strategys, DAX0-1;TEC0-7
Ford Pilot injection
2005 F250 6.0L XLT CCLB 4x4 auto
Strategys, UPV1;URV0;CYH0-7
PowerMax-KTS 11 blade SP Billet
ARP studs, BPD EGR cooler, 04 uppipe
Banks intercooler system, Airaid Dropin
4" turbo back Magnaflow exhaust w/4" DP
SCT 3015
ID custom tunes
ID Pilot-Injection
ID FICM tune
U235a4 is offline
post #5 of 10 Old 05-30-2013, 06:35 AM Thread Starter
jetjock15's Avatar
Quoted: 113 Post(s)
Another thing to mention is php openly states ther is less to gain the bigger you injectors are for what that's worth. So I'd expect more performance gains with stock stocks.
post #6 of 10 Old 05-30-2013, 08:21 AM
nordstrom's Avatar
Quoted: 2 Post(s)
So I bought the tuner from bill a couple months back and have only ran the Econo and Atlas 40. I am running stock sticks and turbo with a MTW billet wheel. I have noticed a big difference on quickness off the line with the 40, I also ran it this last weekend with my tow tune pullin a pretty good mountain pass going from sea level up to around 5500 feet. My Egt's stayed pretty good never saw more then 1250* for a short time. Only noticed a little smoke on start-up and when I would romp on it from a cruise. Overall I am happy with it so far as well
2006 F350, Holders Ported Intake, ARP Studs, Factory Turbo w/MTW Billet Wheel, Edge Insight, Atlas 40 FICM Tune, Stock Sticks, BPD Ficm 53V, BPD EGR Cooler, BPD Remote Oil Cooler W/ cold weather pkg, BPD Water Pump, Blue Spring Upgrade, S&B Cold Air Intake, CCV Relocate, 64K miles and counting
nordstrom is offline
post #7 of 10 Old 06-01-2013, 02:12 PM
406to907's Avatar
Just got done installing my new FICM (went with the premium package with lifetime warranty) from FICM Repair, had them add the ATLAS 40 while they were at it and I couldn't be happier. Truck runs awesome and gets up and goes much better than it did before. It does blow a little smoke off the line or when I hammer down but it cleans up quick and doesn't last long.
Hope this helps somebody make a decision if your on the fence about buying it. Quit thinking and go do it.
06 6.0 CCSB: 4.5" BDS Lift, 18" XD Rims, 35" Trail Grapplers, Custom front bumper, Rigid Flood lights, 5" Diamond Eye Turbo Back Exhaust, Edge CTS Insight, High Idle Mod, FICM Repair.com premium FICM W/Lifetime warranty, ATLAS 40 Tune, Blue Spring Mod, SCT with Custom Tunes, EGR delete, coolant filter kit...
406to907 is offline
post #8 of 10 Old 06-01-2013, 03:15 PM
Soledad's Avatar
Garage
I just ordered the PHP remote programmer 3 days ago and will be going straight to the Atlas 40. This will be on a completely stock '06 with the only mod being the blue spring (well and fuel pressure and pyro and scangauge 2 gauges).
I'm hoping I will feel some sort of difference. This thing can't get here soon enough.
2006 F-350 XLT FX4 SCLB 6.0L | TTY head bolts | stock EGR and cooler | blue spring FP mod | PHP Atlas 40 FICM tune | ScanGauge 2 & GlowShift 3-in-1 gauge (Boost/EGT/FP) | PMM coolant filter kit | Flo~Pro 4" turbo back w/muffler | stock tune
Soledad is offline
post #9 of 10 Old 06-01-2013, 03:29 PM
RAMAIRIII's Avatar
I too have the Atlas 40 from Ed and you can really tell a difference off idle. Your gonna like it!
Sent from AutoGuide.com App
RAMAIRIII is offline
post #10 of 10 Old 06-03-2013, 10:59 AM
Lets say i did a intake, portet manifold, MTW billet wheel on 03 stock charger and added these mods the atlas 80 plus matts or tonys tuning, 155/30 inj would be too high egt's if running performance tunes without pulling fuel..
07 f350 DRW
Thanks
Bloodstain is offline
