PHP FICM Programmer??? - Ford Powerstroke Diesel Forum
post #1 of 7 Old 05-29-2013, 07:45 PM Thread Starter
Bump To Pass!!
toren302's Avatar
Quoted: 1783 Post(s)
Alright well first off I searched this forum and PHP's forum and couldnt find an awnser. I think I will call tomorow if nobody knows. My question is:
I have a early build 04 with a FICM from an 06. The tuner has tunes for 03, 04, and 05+. Common sense would say use the 05+ with the 06 FICM I have, but has anybody noticed any issues going with the others? I am just curious if there is a diffrence in them. I tried the 03 atlas 40 and seems to be better throttle response but I didnt want to hurt anything so I switched it to the 05 calibration. Sorry if this was already covered and I missed it. Thanks for any help in advance.
Originally Posted by Heavy_GD View Post
Merged, because lamp.
toren302 is offline
post #2 of 7 Old 05-30-2013, 03:18 AM
Powerstroke Techie
Lilpooh's Avatar
Quoted: 10 Post(s)
Feedback Score: 3 reviews
Try this.
http://forum.gopowerhungry.com/6-0l-...ogramming.html
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #3 of 7 Old 05-30-2013, 03:19 AM
N.S.D.Q.
HeavyAssault's Avatar
Quoted: 158 Post(s)
While the FICM may physically be a 2006 it's a matter of the tuning loaded on the logic side.
Officially The Biggest Midget In The Game
(In support of Zmann's request)
HeavyAssault is offline
post #4 of 7 Old 05-30-2013, 07:25 AM
Chatham036's Avatar
Quoted: 150 Post(s)
This is correct. Your truck is set up to run a particular FICM code that varies with model year.
I would imagine that your 06 FICM was reflashed to work with your 04 build. therefore I would suggest the use of the 04 tune set.
Your truck will throw a P0306 code if you install the wrong code set.
this code stands for software incompatibility in the FICM
Comments or opinions expressed by me do not necessarily represent the views of PHP, its management, nor its employees. PHP is not responsible for, and disclaims any and all liability for the content of comments written by me.
Chatham036 is offline
post #5 of 7 Old 05-30-2013, 08:56 AM Thread Starter
Bump To Pass!!
toren302's Avatar
The ficm was not reflashed. I know that for sure. That's why I asked the question. Should I use the 05 tune or the or one of the others? Also if the code is the only issue does it really matter which ine is used?
Sent from AutoGuide.com App
toren302 is offline
post #6 of 7 Old 05-30-2013, 09:26 AM
Chatham036's Avatar
Quoted: 150 Post(s)
Reading over my response, I wasn't clear enough in my message.
There are two different types of FICMs, the seven pin and the four pin.
All of the four pins have the same hardware
All of the seven pins have the same hardware
The issue that people run into has to do with the FICM tune compatibility with the trucks ECM. If the ECM is an 04, you will want to have the 04 tune installed on the FICM. The variation in FICM files is to keep a perfect match to what the ECM is.
I have not seen nor heard of anyone experiencing any damage due running the wrong file, but most will trip the P0306 code I mentioned in my last post. The way to correct this is to put the proper file in the FICM. We suggest you run the tune that is proper for your model year
post #7 of 7 Old 05-30-2013, 10:17 AM Thread Starter
Bump To Pass!!
toren302's Avatar
Awsome thanks so much that's what I wanted to know.
toren302 is offline
