borg warner turbos? - Ford Powerstroke Diesel Forum
post #1 of 21 Old 05-29-2013, 12:03 PM Thread Starter
LiftedStroker05's Avatar
borg warner turbos?
I have been looking into the borg warner s300 and s366 turbo for my truck and i keep seieng this t3-t4 flang or something. just wondeirng if you all could help me out on that. if i get a s300-s366, will i need this flang to make things work?
'05 f250 6.0 stroker
ARP studs, Barder fmws468, warren 225/75s,EGR delete, stage 3 hdp trans
4" MBRP to 7" tip,sinister collany system
sct tuned w/ SRL++ xtreme tune
20x12 riots with 420s
Air Dog fp150 w/ 1/2" fuel lines,blue spring mod,
zoodad mod,traction bars
LiftedStroker05 is offline
post #2 of 21 Old 05-29-2013, 12:14 PM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
Feedback Score: 10 reviews
Yes it is a V-band adapter. It allows you to use OEM up pipes on a t4 style exhaust connection. You can eliminate that with a set of divided up pipes that have the t4 adapter welded on it.
l BRYAN l
COMPIGNTECH .COM
Look us up on Facebook
COMPRESSION IGNITION TECHNOLOGIES
l 2005 l Ford F250 l FTX l
[A Few Odds-N-Ends]
Tuscany is offline
post #3 of 21 Old 05-30-2013, 04:59 AM
Turbos = Witchcraft
TooMuch03's Avatar
Feedback Score: 3 reviews
Yeah, you would be better off to buy a set of T4 divided up-pipes (for the price of those damn adapters, you might as well) then you can install any S300 series turbo with a T4 divided turbine housing. What size injectors are you thinking of running with this turbo?
2003 F250 6.0
Originally Posted by Tuscany View Post
Compounds FTW!!!
TooMuch03 is offline
post #4 of 21 Old 05-30-2013, 05:04 AM
I would not run the adapters. I'm in the process of making my own up pipes. Doesn't look to hard.
Ryan
2003 2wd 6.0 egr gone, blue spring, extremeX
305/50/20 nitto 420s (lowered in the rear)
205/100 bw66
Boost got you loose
13.4 with a 1.9 60ft spinning anit winning
YOUR CUMMINS MIGHT BE FAST BUT YOUR GIRLFRIEND LIKES MY SLOW POWERSTROKE
my youtube channel mostly 6.0 videos
risco is offline
post #5 of 21 Old 05-30-2013, 05:31 AM
Turbos = Witchcraft
TooMuch03's Avatar
Its not, if you can weld, or have friends who can like I do
2003 F250 6.0
Compounds FTW!!!
post #6 of 21 Old 05-31-2013, 08:23 AM Thread Starter
I myself am a welder so i could probably take care of the up pipes. As for injectors, im thinging 190/stock for now. Then maybe some bigger nozzles later on down the road
post #7 of 21 Old 07-08-2013, 08:41 PM
onebadcoastie's Avatar
Quoted: 10 Post(s)
Glad I came across this thread. I've been tinkering with the idea of running an S366 with my 175/75's. Thinking with the right tuning, I can make that a great tow rig and still have fun with it. Any thoughts?
Shack
2016 F-350 CC Dually
2005 F250 CC FX4.SOLD
onebadcoastie is offline
post #8 of 21 Old 07-09-2013, 04:07 AM
BACKYARDIGAN
windrunner408's Avatar
Quoted: 4 Post(s)
I don't think a 366 will work too great for towing. I know guys have towed with it, but I don't think they've done cross country towing of heavy weight.
Nate
2006 F350 (BACKYARDIGAN) - 67mm Turbo, 215/85 injectors, WPE intake manifold, NB/Warren Trans, and more stuff that I don't care to mention....
2006 F250 (LITTLE DURTY) - WPE Manifold, Up-pipes, EGR delete kit, and Tuned By ME
BULLET PROOF DIESEL 1-888-967-6653
KC TUROS - Not just a modified Powermax...
WINDRUNNER PERFORMANCE ENGINEERING
windrunner408 is offline
post #9 of 21 Old 07-09-2013, 05:47 AM
Turbos = Witchcraft
TooMuch03's Avatar
A 62 or 64 would be a better option. I would opt for the 68mm turbine wheel with the .83 T4 divided housing.
2003 F250 6.0
Compounds FTW!!!
post #10 of 21 Old 07-09-2013, 06:26 AM
Quoted: 10 Post(s)
Thanks guys. Still undecided.
Shack
