Who's maxed out 190's? - Ford Powerstroke Diesel Forum
post #1 of 29 Old 05-28-2013, 08:30 PM Thread Starter
Dirty_Stroke's Avatar
Ok guys I'm on the edge of pulling my 155's and stepping up to some bigger sticks. I would like to know what is the max hp to be expected if I went with 190/75's or 190/100's? I'm obviously talking about matching a larger turbo with the sticks. I'm wanting the truck to be over 600rwhp. Just curious if I stepped into the non-VGT world would 600+ on 190's be possible? Something like a 66mm? I know I have lots of questions but I'm ready to make some serious power and don't want to blow a bunch of money and be disappointed.
05 F250 FX4 Lariat, SCT Livewire, 155cc injectors, Gryphon FICM tuner, ARP studs, MTW Stage 2 Turbo, Riff Raff boots, Warren Built trans, PMF traction bars ,4 inch straight pipe, Sinister EGR delete, S&B CAI, N-fab bars, level kit, 5% limo tint, 35 Toyos and 20s, Recon smoked everything, Harley headlights, 5k HID's, Camlocker toolbox, lots more
Dirty_Stroke is offline
post #2 of 29 Old 05-28-2013, 09:38 PM
Making ported intakes
ODAWG714's Avatar
Quoted: 6 Post(s)
I know you should be in the 600s for sure with a 68 vgt, I guess Nate hit 605? And a guy on the army hit 599 with a rcd68 and 190/100s
Pizza pig would be able to hook you up on the non vgt questions
Oliver
6.0/6.4 Ported intake manifolds, turbos, air intakes, fuel systems and much much more!!!!
ODAWG714 is offline
post #3 of 29 Old 05-29-2013, 03:10 AM
JGman141's Avatar
I'd go with 205/100s and a mad stage 4. If you want to go non vgt then an s366 would work well. That will put you over 600 hp.
2004 6.0 ccsb Warren 430/150 hybrids, Warren Comp Trans, Warren Dual Hpop, Billet S475 w/race cover, Marty's A1000 Fuel System, Colt stage 2 and all the other supporting stuff
JGman141 is offline
post #4 of 29 Old 05-29-2013, 03:10 AM
the chad's Avatar
I'd say bt 6-650 unless you did some crazy compound setup
Chad
07 F250
4'' MBRP to 7'' FTE Miter
ELC w/ Sinister Coolant filter
ARP's with OEM
Edge CS and Trans, Boost, FP on the pillar
Voltmeter in dash
Banjo's
Looney
Cal-Tracs
20x10 Monsters wrapped in 305 420s
RCD Egr Delete
Warren 190/75
Dozers RR
MTW Stage 2
557 hp/1206 ft/lbs
Big thanks to JJ @ Dozers And Adrian at MTW
the chad is offline
post #5 of 29 Old 05-29-2013, 10:04 AM Thread Starter
Thanks for the replies guys. If I ran the S366 in this kit and 190/100's would I clear 600? How streetable would it be? Is there any chance at all that I could tow if I had to? Here's the link to the kit: Ford 6.0L S300 Turbocharger Kit
For the money that looks like a quick way to get to the power level I'm looking at. Would it be better to buy there kit without the charger and get my own?
post #6 of 29 Old 05-29-2013, 10:17 AM
Turbos = Witchcraft
TooMuch03's Avatar
Feedback Score: 3 reviews
If I were you, I would call Matt at cutting edge, have him send you his up-pipes and drain tube, then buy a box 66/73/.91 t4 divided turbo. It would be cheaper and the 73mm turbine is a low inertia inconel wheel that will defintely spool faster than the 74mm offered with that kit.
Why not go to 205s? Then I think you would be all but guaranteed 600 hp
2003 F250 6.0
Originally Posted by Tuscany View Post
Compounds FTW!!!
TooMuch03 is offline
post #7 of 29 Old 05-29-2013, 10:29 AM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
Feedback Score: 10 reviews
I honestly think that with 190/100's 600+ is VERY attainable. There have been multiple trucks to hit that mark with those injectors now and a MTW Stage 3.
l BRYAN l
COMPIGNTECH .COM
Look us up on Facebook
COMPRESSION IGNITION TECHNOLOGIES
l 2005 l Ford F250 l FTX l
[A Few Odds-N-Ends]
Tuscany is offline
post #8 of 29 Old 05-29-2013, 12:29 PM
Quoted: 5 Post(s)
Oh I dont know if he still has them but gary (g2_shuck) had a couple 366's for sale I think for a good price.
May want to PM him.
2005 Harley F-250 CCSB
True Blue Metallic
Engine: ARPs, OEM oil cooler, Bed plate reseal, OEM HGs, Stand Pipes, Dummy Plugs, STC Fitting update, Bulletproof EGR, Rotella Ultra ELC, Sinister Coolant Filter, Machined stock heads, Blue spring
Exterior: Nitto Terra Grappler 295/60/20s on stock Harley 20s
Interior: Edge Insight CTS w/ EAS Fuel Pressure & EGT
Trans: PI Stallion, Billet input shaft, new clutches, 08 pan/filter
white59rt is offline
post #9 of 29 Old 05-29-2013, 01:20 PM Thread Starter
The reason I was looking at the kit was because everywhere that I've looked at up-pipes they want almost as much for just the pipes as these guys want for a whole kit that includes a turbo. I haven't price checked 205's but I assume they would be a good bit more than 190's and I was under the impression that with 205's you can forget towing anything. I do still need to be able to haul the boat to the river and pull my jeep when necessary. So I could buy that kit without the turbo for $700 and then get whatever T4 turbo that would work best. Is that the route I should check into?
White59rt, thanks for the heads up. I will shoot Gary a text message.
post #10 of 29 Old 05-29-2013, 01:44 PM
william_ace's Avatar
Quoted: 2 Post(s)
Very interested to see how all of it turns out. I'm tempted to go this way myself.
2004 CCLB 6.0 6 speed 4x4
ARP Studs with OEM Gaskets
Barder Stage 3 / Holders 205/100s
Southbend Dual Disk Clutch
Odawg fully ported and deleted intake manifold
4" MBRP Turbo Back
Windrunner regulated Return with custom Y-pipes
Cat EC-1 with coolant filter
Flyin Diesel Sump w/ fuel lab 4201
william_ace is offline
