FICM upgrade/core - Ford Powerstroke Diesel Forum
post #1 of 12 Old 05-27-2013, 01:42 PM Thread Starter
406to907's Avatar
FICM upgrade/core
Here's my dilemma, Looking at getting a 58v FICM and my oem one is going south (when I start the truck its around 35v then after warming up a while and driving will bounce between 47.5-49v) I'm looking into the 58v due to living in Montana and plugging in is not always an option and cold starts between 20 to -20 or so are also not uncommon for 6 months out of the year so figured the 58v would give me better cold start benefits.
The problem is that my truck is my DD and only form of transportation and every company I've seen for an aftermarket FICM wants you to send in your core before they will send you a new one or update yours and send it back and I really can't afford to be down without a truck for a week or more. Was going to call a few of the local shops around here and see if they would have one laying around I could use as a core then give them mine once the new one comes in but are there any other options out there? I know I could do the BPD but was really looking into Swamps 58v FICM.
So basically is there any company out there that I can buy a 58v FICM (maybe with a tune), while keeping my OEM FICM until I get the new one?
Sorry for the long post and hopefully somebody knows a way around having to send my OEM FICM in and being stuck without a rig.
Thanks
406to907 is offline
post #2 of 12 Old 05-27-2013, 02:08 PM
Ficmrepair I beleave will send you one out before the get your core and they do tunes. But they don't do the 58v mod . Ed is a great guy to deal with tho
this is wallie (grey truck)04 ccsb 6.0 4x4 f250 8 inch lift 38s edge insight cts,sct sf3,egr delete,cat delete,warren 175s,arp studs,oem head gaskets , stock turbo .s&b intake,4" mbrp straight pipe. (Red truck) this is Eva 01 ccsb 4x4 f250 5.4 6 inch lift 33" tires super turd lol
92f150300six is offline
post #3 of 12 Old 05-27-2013, 02:20 PM
sprksonu's Avatar
even though the BPD 58v ficm is a little expensive i can almost guarantee it will be the last ficm you purchase. everything inside of it is military grade electronics and the cnc billet shell reduces heat compared to a stock unit. i have the 4 phase 48 volt and it is a great unit always runs 49v. if you decide to get the BPD unit you can rent a ficm tuner from php for 150 program it then mail it back within a week
WRECKED EM DAMN NEAR KILLED EM!
2005 f250 ccsb 4x4 Studded, 03 turbo w/billet wheel, AFE stage2, 5"diamond eye, BPD egr cooler & "NEW" external oil cooler, BPD 48v FICM, BPD water pump, BPD aluminum radiator, 6.4 banjo's, blue spring, HFCM e-z drain, riff raff boots, gearhead srl tune , PHP FICM tune, sct livewire 5015, updated stc, updated stand pipes & dummy plugs, updated oil feed & drain, Zerex ELC coolant, Pro Comp 6" lift, 325/70/17 Toyo open country at
sprksonu is offline
post #4 of 12 Old 05-27-2013, 02:29 PM
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
The FICM you'll never fix again. No core necessary
FICM Bullet Proof Fuel Injection Control Module Update
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is offline
post #5 of 12 Old 05-27-2013, 02:33 PM
Term3's Avatar
Quoted: 2 Post(s)
Keep in mind a vast majority of FICM failures are due to the power supply board so even though your FICM is showing signs that its failing I can almost guaranty that the logic side of your FICM is fine. I would buy the BPD FICM power supply upgrade (I HIGHLY recommend setting it to 58 volts). Other FICM suppliers just re-solder the OEM crap circuit board and send it back so what's the point of buying that? You can swap in the new BPD FICM 58 volt power supply in about 15 minutes tops.
Sent from AutoGuide.com App
SCT, no studs...yet, Dual OEM intake air filter housings, Banks intercooler & intake elbow, Banks exhaust system, Windrunner ported intake manifold, Bullet Proof Diesel remote oil cooler & thermostat, AirDog2 (plus a couple spares), Power steering filter (Amsoil dual-bypass), MagTec deep ATF pan, Electric oil pre-lub pump, Dakota Digital gauges.
Term3 is offline
post #6 of 12 Old 05-27-2013, 05:00 PM Thread Starter
406to907's Avatar
At this point FICM Repair is looking like the most feasible and realistic option, the BPD one would be sweet but a pretty heavy price tag...Should I go with the Atlas 40 tune while I'm at it? I'm pretty much stock minus edge CTS insight and 5" turbo back exhaust. Planning on doing EGR delete and SCT down the road. Will the Atlas 40 be worth doing now or after the tuner?
06 6.0 CCSB: 4.5" BDS Lift, 18" XD Rims, 35" Trail Grapplers, Custom front bumper, Rigid Flood lights, 5" Diamond Eye Turbo Back Exhaust, Edge CTS Insight, High Idle Mod, FICM Repair.com premium FICM W/Lifetime warranty, ATLAS 40 Tune, Blue Spring Mod, SCT with Custom Tunes, EGR delete, coolant filter kit...
406to907 is offline
post #7 of 12 Old 05-27-2013, 05:06 PM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
Feedback Score: 10 reviews
Listen, the BEST FICM repair job with their best warranty is going to set you back $500. Why not just buy the 48v 4 Phase BPD FICM for $500 and NEVER worry about it again. You don't NEED a 58v FICM and if you were to run one at 58v the only one I would EVER recommend doing so with would be the BPD unit. The OEM boards and components aren't designed to run with such high voltage and current flowing through them and often burn up so badly that you will end up having to buy yet another FICM. Do it right the first time and be done with it. BPD all the way.
l BRYAN l
COMPIGNTECH .COM
Look us up on Facebook
COMPRESSION IGNITION TECHNOLOGIES
l 2005 l Ford F250 l FTX l
[A Few Odds-N-Ends]
Tuscany is offline
post #8 of 12 Old 05-27-2013, 05:11 PM
Ed at ficm repair will do an exchange, so you don't have any downtime. After your rebuilt ficm is installed, just ship your old ficm back and you are done.
Yea, the Atlas 40 is worth doing before your tuner.
darenative is offline
post #9 of 12 Old 05-29-2013, 11:33 AM
6.0DSLPWR's Avatar
I would go with the BPD ficm over the swamps I have a 1.5 year old swamps 58 volt ficm that drops to 46V every morning and has started to flucuate alot while driving. Due to this I am now looking into a BPD ficm.
-Aaron
2005 Ford F350
SCT X3
Isspro Performax Gauges
Dieselsite Boots
Fumoto Oil Drain
Coolant Filter
MBRP Dual 4" Straight Pipe
Harley Headlights
Pioneer In Dash GPS
6000K HID Headlight and Foglights
Smoked Lights
6.0DSLPWR is offline
post #10 of 12 Old 05-29-2013, 03:27 PM Thread Starter
406to907's Avatar
Thanks for all the reply's and insight on this. I went with FICM Repairs premium package 48v FICM with Lifetime guarantee/warranty with the ATLAS 40 tune and will be installing the "Blue Spring" along with it. Should be here by Friday so I can get it all put together Friday evening. Feels like I've been hemorrhaging 100 dollar bills lately for this truck...Gotta pay to play though, next up EGR delete, SCT Tuner, Coolant filter kit, EGT and fuel pressure gauges...
406to907 is offline
