exhaust sound - Ford Powerstroke Diesel Forum
post #1 of 5 Old 05-26-2013, 08:15 PM Thread Starter
exhaust sound
Just wondering....I just installed a 4" exhaust from the turbo down with no cat and mufflers. This is my first diesel too. How is it suppose to sound like? Mines sounds like air is just rushing out when it sits at idle then the tone changes from air rushing out to low tone for about 2seconds then goes back to the sound of air rushing out. Is that normal? I got the diamond eye exhaust. I was thinking of getting the connections all welded instead of clamps. lmk guys thx
darren808 is offline
post #2 of 5 Old 05-26-2013, 08:19 PM
Normal sounds like a hair dryer
mikeproc is offline
post #3 of 5 Old 05-26-2013, 08:20 PM
kirbybc12's Avatar
That's what my truck sounded like with a resonator. I also had a leaking up pipe though, so I'm not sure if its supposed to whistle entirely at idle or only at higher RPMs. If you have the exhaust welded you won't be able to remove it without cutting it like the stocker, just keep that in mind.
2012 F-350 Lariat FX4 CCSB
2.5" Carli Commuter
Carli High Mount Steering Stabilizer
AFE Cold Air Intake
Truxedo Lo Pro QT
Line-X
Dura-Flap Mud Flaps
Timbren SES
High Idle
35x12.5x20 Toyo AT II Extreme
H&S Mini Maxx, 4" AFE Turbo Back
kirbybc12 is offline
post #4 of 5 Old 05-26-2013, 10:33 PM
sprksonu's Avatar
it is completely normal it is the turbo doing a vein sweep, keeps the turbo from getting gunked up with soot
WRECKED EM DAMN NEAR KILLED EM!
2005 f250 ccsb 4x4 Studded, 03 turbo w/billet wheel, AFE stage2, 5"diamond eye, BPD egr cooler & "NEW" external oil cooler, BPD 48v FICM, BPD water pump, BPD aluminum radiator, 6.4 banjo's, blue spring, HFCM e-z drain, riff raff boots, gearhead srl tune , PHP FICM tune, sct livewire 5015, updated stc, updated stand pipes & dummy plugs, updated oil feed & drain, Zerex ELC coolant, Pro Comp 6" lift, 325/70/17 Toyo open country at
sprksonu is offline
post #5 of 5 Old 05-26-2013, 10:38 PM Thread Starter
Oh ok thx man. I thought something was wrong. Lol
Sent from AutoGuide.com App
