66 non vgt with 190s? - Ford Powerstroke Diesel Forum
post #1 of 10 Old 05-26-2013, 07:13 PM Thread Starter
617mach 1x's Avatar
found a 66/68/.83 t4 divided, just wondering if anyone has run this setup?
any towing possible?
ported intake manifold
fuel system
190/75
intake
and the normal other 6.0 stuff
studded, stacked,chipped
trans, turbo, tire and injectors??
617mach 1x is offline
post #2 of 10 Old 05-26-2013, 07:16 PM
Sounds like a good setup.
Just get some good custom tunes and an egt guage for towing.
You will need to downshift for hills to keep egt's low.
cfd_shop is offline
post #3 of 10 Old 05-26-2013, 07:18 PM
kdogg85's Avatar
10k or less is where I would be comfortable towing with that. The intake will help a good bit. Getting the heads worked would greatly help as well, but that's very expensive to have done.
General driving, it would work great and be fun.
David
05 f250 ( double your pleasure ) underway
'10 f250 ccsb 4x4, project super mom 366/515 compounds, 200hp sticks, and all the other goodies
Most importantly, the car seat mod
kdogg85 is offline
post #4 of 10 Old 05-27-2013, 06:02 AM Thread Starter
617mach 1x's Avatar
Thanks guys, what have guys been seeing for hp # with similar setups?
Sent from AutoGuide.com App
post #5 of 10 Old 05-27-2013, 06:48 AM
I think 550-575 would be pretty realistic.
Don't know if you are spraying it or not, but with a .83 a/r you will need to install a wastegate if you do.
cfd_shop is offline
post #6 of 10 Old 05-27-2013, 08:20 AM Thread Starter
617mach 1x's Avatar
dont plan on nos, maybe w/m to cool things down
post #7 of 10 Old 05-27-2013, 02:46 PM
I had a truck once in the same shape, as far as big turbo for towing.
I would empty a 1.5 reservoir of w/m after 2 mountains, but it kept it cool.
I also think that was what bent the rod in the engine fwiw
cfd_shop is offline
post #8 of 10 Old 05-27-2013, 03:17 PM Thread Starter
617mach 1x's Avatar
What size injectors and turbo specs did you have?! Might get it live tuned if I can max I tow is 10k and not through huge mountains
post #9 of 10 Old 05-27-2013, 06:04 PM
That was a 4094 vgt turbo and 45% over injectors, lbz cp3 on a lly duramax.
You will be fine with the turbo light towing. It will perform great
cfd_shop is offline
post #10 of 10 Old 05-27-2013, 09:45 PM
pizza pig's Avatar
comparing any charger this size on a 6.0 to a duramax is straight foolery
pizza pig is offline
