Newbie Tuner Question? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 05-25-2013, 12:55 PM Thread Starter
I recently purchased my first diesel, (05 f 250 crew) I read the sticky that says you should take it back to stock before changing to a different tune. My question is how do I do that if it is just a flash tune, also I don't even know for sure if it has a tune on it, I assume it does because I found a reciept in the glove box, and it has 315/70/17s and the speedo is correct? The truck does have the egr delete and straight exaust, no converter, I don't know about any other mods. Truck is my daily driver and I tow a 35ft camper so I thought a tuner I could switch would be best. What would be the best way to go? Any info would be appreciaated!
Thanks,
Pete
Bikertrash1 is offline
post #2 of 6 Old 05-25-2013, 04:59 PM
rogerallen33's Avatar
What type of tuner do you have,, I recommend the sct for the 6.0,,,, you don't have to take it back to stock before you change tunes,,, the only time you take it back to stock is if you , change to a different tuner, you can't program a truck with 2 different tuners,, if you ever take it to have it worked on return it to stock, and since you tow, you want to use a tow tune, and not a 120 hp tune, another words don't try and tow that camper with a high hp power tune, you will end up tearing something up, I would tow that with like a 50 to 80 hp tow tune, a tuner is great to have but if you go messing with the setting and don't set it up right, you can run into problems,, I don't tow much so I run a 120 performance tune, and I have the tranny set for firmer shifts, and everything is great with the truck, great mpg as well,,,, I hope this helps you
rogerallen33 is offline
post #3 of 6 Old 05-25-2013, 05:01 PM
ohh if you truck all ready has a tune on it and you bought a tuner to put on it,,,, it won't program it,,,, you will have to take your truck to ford and have a reflash done and then you will be able to tune the truck, once you drive a tuned truck, you really won't ever drive stock again, a lot of times if the truck is already tuned, if you run the dtc's you will get a code,,,, I think it is a p0603code, not sure about that number,, but ,, it will say something like keep alive internal memory (kam) error,, something like that, which all it means is that the truck is tuned
post #4 of 6 Old 05-25-2013, 06:31 PM Thread Starter
Thanks for the reply, I'm not sure of all the lingo, but I think my truck has a flash tune. The main reason I think so is it has 315/70/17's on it and the speedometer is accurate. I will check to see if there are any codes on it.
post #5 of 6 Old 05-25-2013, 07:15 PM
the easiest way for you to find out is ,, if you have a way to read the dtc's, you can also go to a parts store o'reillys , auto zone and have them scan it, if it is tuned, I would have it reflashed by ford back to stock, and then put a new tuner on it, if it's tuned it should though that code, but it doesn't always though it,,, good luck
post #6 of 6 Old 05-26-2013, 06:37 AM Thread Starter
I have a scanner so I will take a look. Thanks for the info!
