MBRP exhaust pipe hitting frame??? Ideas how to fix? - Ford Powerstroke Diesel Forum
post #1 of 13 Old 05-24-2013, 07:26 AM Thread Starter
baycountry16's Avatar
Like title states, I have 4" MBRP straight piped and pipe is touching frame right in the first straight section after down pipe.heading back. Makes a loud clang when I hit a bump and I think I'm getting some vibration when I hit accelerator hard as well. Anyone had this happen and have an idea how to fix the problem? Thanks for the help
Sent from AutoGuide.com App
2006 F-250 King Ranch Crew Cab Long Bed
146,000 miles and counting....
Mods so far....More to come
ARP Head Studs
Custom Diesel EGR Delete
4" MBRP Turbo Back Straight Piped Exhaust
Zerex CAT ELC Coolant
Updated STC Fitting, Turbo Feed and Drain Tube
PMM Coolant Filter
Blue Spring Upgrade
High Idle Mod
Edge Insight CTS
Edge expandable EGT Probe
Edge Fuel Pressure Sensor
SES SS Billet Grille Inserts
Recon Smoked Cab Light Covers
baycountry16 is offline
post #2 of 13 Old 05-24-2013, 07:30 AM
2000-7.3L's Avatar
Feedback Score: 10 reviews
Cant you take an exhaust strap and bolt it to the frame, then it wont move around? Post a pic of where it is hitting!
2000-7.3L is offline
post #3 of 13 Old 05-24-2013, 07:36 AM
strokin6L's Avatar
Quoted: 4 Post(s)
Installed a few with never a problem. Try repositioning the pipe.
2004 F-350 SC 4x4, XLT, 4" dual Magnaflow, AFE intake, No Limit piping, spearco intercooler, water injection, ARP studs, hypemax o-ringed heads, SCT tuned by Innovative Diesel, tuned FICM, Hellman's sump, FASS, Fuelab, regulated return, 190/75 injectors, KC/MTW 68 w/.72ar, suncoast trans w/billet input, edge insight CS with dakota digital gauges, amsoil by-pass, BD exhaust manifolds
strokin6L is offline
post #4 of 13 Old 05-24-2013, 07:40 AM
Snake's Avatar
Quoted: 46 Post(s)
Loosen the clamps. Place a piece of wood between the pipe and the frame where it's making contact. Tighten clamps. Remove wood.
Truckless
Bulletproof Diesel
KC Turbos
1-A Auto Parts
Snake is offline
post #5 of 13 Old 05-24-2013, 07:56 AM
strokin6L's Avatar
Quoted: 4 Post(s)
Or try loosening the clamp for the downpipe and roll/twist the downpipe. This way the other end of the downpipe will be at a different angle. Hopefully not angling towards the frame where its hitting.
post #6 of 13 Old 05-24-2013, 08:06 AM
Eric@PTP's Avatar
This........
1-888-516-4644
GO NAVY
Eric@PTP is offline
post #7 of 13 Old 05-24-2013, 08:30 AM
twoicebergs's Avatar
Quoted: 47 Post(s)
You are probably not fully up on the down-pipe or it is slipping down. It is a common problem. Loosen and hit with a soft hammer and reclamp, very tight. If you break the clamp (not likely) or it still slides, mark it and pull them both off, then drill a hole and after it is back on the truck, install the SS screw and reclamp. Another hanger may help.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #8 of 13 Old 05-24-2013, 12:00 PM
This is what I did and work awesome, my new exhaust does not hit at all
Late 04 f350 lariat.
bpd
marty's regulated return
205/75 injects from holder's
WPE stage 3 ported intake
64.5 borg warner fmw ,compounds in the works now! Comp turbo set up
Warren comp trans
all the typical mods
Big thanks to Dale! The man is a true professional
04cr450 is offline
post #9 of 13 Old 05-24-2013, 12:29 PM
new2deisel's Avatar
I never had a problem with exhaust hitting frame but my downpipe would move while offroading and hit pinch weld. I removed exhaust hanger along frame and added a couple washers in there to move hanger off frame a little and bolted hanger back up. No more problems.
new2deisel is offline
post #10 of 13 Old 05-24-2013, 01:03 PM
Powerstroke Techie
Lilpooh's Avatar
Feedback Score: 3 reviews
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
