SCT problem - Ford Powerstroke Diesel Forum
Old 03-08-2008, 01:53 PM
Exclamation SCT problem
i got in my truck today and had my commander just installed and had my truck set on stock to i changed it to streetsmoke and drove around for a while then changed it back to stock then i tried street smoke 2 a differnt smoke tune and while it was at 50% i opened my door to get a soda and came back and it said TBC FAULT in the dash and soon after that my tuner said error on upload file and now i cant upload any files and it says i cant change my truck back to stock either cause of file not be there or somethin?
Old 03-08-2008, 01:58 PM
ADMIN AND TECH
its not a good idea to swap tunes around alot , are you sure you followed the prompts correctly,are the batteries charged good , if pcm power drops below about 10 volts its possible to not have been able to finish correctly, the more you mess with it the worse you can make it , you may have wiped the pcm
Old 03-08-2008, 01:59 PM
Rob Rob is offline
Call Vivian, they know more than most of us and im sure they can get it figured out for you.
Old 03-08-2008, 02:15 PM
i tried there cell and home phone but no one is around i was gunna go out tonight and show off my new tuner to my pals but guess the fun has to wait till another night bummer lol
Old 03-08-2008, 02:58 PM
email or call eric at innovative. he might be around on the weekend
Old 03-08-2008, 03:06 PM
Rob Rob is offline
I would keep callin bud, they are hard to get hold of sometimes!
Old 03-08-2008, 05:25 PM
Did you save your stock file to your PC?
Old 03-08-2008, 06:10 PM
yeah i saved it but when i went to look at it today it says stock fbu or somethin like that but it has 0 kbs or its blank i remeber transfering my stock file to my computer but its blank on here?
Old 03-08-2008, 06:20 PM
well I dunno if you tried emailing innovative but I PMed him around 5pm and had a response by 6:30.
Old 03-08-2008, 06:21 PM
You mean it's blank on your SCT or blank on your PC? It should be saved on your PC as an .lbu file. Mine is like 768KB. I believe you should be able to transfer that file back to your SCT, unless your SCT got corrupted. Unless its blank on your PC, if thats the case, I
