Having a tune on stock head bolts - Ford Powerstroke Diesel Forum
post #1 of 8 Old 05-23-2013, 02:18 PM Thread Starter
Hello
I got my truck in the shop and wanted to know how many people have a good quality custom tune on their stock headbolt/gasket 6.0L and haven't had issues in the long term. I am speaking for Economy and Tow tunes not the super high horsepower ones.
15 F250 XL 6.7L CC LB 4x4 (temp work truck)
03 Excursion Ltd 6.0L ARP studs/HG, turbo back exhaust, K&N CAI, EGR delete, 6.4L banjo bolts, blue spring, coolant filter, IDP tunes, SCT Livewire (regrettably sold)
08 Jayco 31 BHDS G2
96 Regal 258 Commodore
rowekmr is offline
post #2 of 8 Old 05-23-2013, 02:56 PM
N.S.D.Q.
HeavyAssault's Avatar
Quoted: 97 Post(s)
Feedback Score: 3 reviews
Don't go getting crazy with it should be your thoughts. It's not a sure thing it won't pop but you never know. I drove with a chip then changed to SCT tuning with no major issues.
Officially The Biggest Midget In The Game
(In support of Zmann's request)
HeavyAssault is offline
post #3 of 8 Old 05-23-2013, 03:36 PM
Chanzfx4's Avatar
Its a chance either way. People run extreme tunes with stock bolts and fair out great and then others blow HG and stretch bolts stock or a moderate tune. Its your gamble but alot of tuners know the limits when they tune.
2003 White F350 Fx4 CC SWR
Go Fasts:
X2 tuned with SRL+
4 Inch Open Dp
Egr Delete
Blue Spring Mod
Riff Raff Boots
Sinister Coolant Filter
All Aluminum Radiator
ZooDad
Looks:
Blacked Tails
285/75/16 Destination M/Ts
Camo Interior
Leveled
Raised Black Nerf Bars
Black Bed Rails
Chanzfx4 is offline
post #4 of 8 Old 05-23-2013, 03:41 PM
I'm interested in this as well. I've got a relatively new to me truck, but have already installed a BPD cooler and EGR delete since I got it. With the EGR cooler out of the picture and the OEM cooler gone how much of a concern is high cylinder pressures (since the threat of coolant dumping back in is gone)?
I guess the main question I have is, can guys with BPD and EGR delete run a little hotter tunes?
tclint1981 is offline
post #5 of 8 Old 05-23-2013, 03:45 PM
N.S.D.Q.
Quoted: 97 Post(s)
It's not a clear answer. There have been so many guys running stock that have had issues. Some people had zero to minor issues running tuned on stock bolts.
Whoever you choose for the tuning should make the tune mild enough for stock bolts and give you a nice power bump.
I'd say since you got the EGR delete done you have one up on the problem.
post #6 of 8 Old 05-23-2013, 04:01 PM
travisH3's Avatar
Quoted: 2 Post(s)
Feedback Score: 13 reviews
I ran Matt Robinson's SRL tune from gear head automotive on my 6.0 daily for 25k miles and wasn't easy on it really. Just did my maintenance and made sure it was up to temp. I had my egr deleted also. But it's no guarantee. It's hit or miss and depends on previous maintenance also.
T-rav
2010 F350 6.4-
s467 MPD single kit, H&S Jesse Byall tuning, No limit IC piping and intake,mishimoto intercooler, MPD billet CCV/oil filler, FASS with sump, SOTA A.W.O.L. polished wheels, toyo rt tires, RED Newton traction bars, oem projector retrofit and a bunch of LED lights LOL
Holderdown Performance #teamHDP
OUR FLEET: 2015 f450, 2014 Platinum F350, 2012 F450 6.7, 2010 F350 6.4, 2005 F350 6.0, 04 F450 6.0
travisH3 is offline
post #7 of 8 Old 05-23-2013, 04:46 PM
Didn't figure there'd be a straight simple easy answer on the stock bolt questions. It seems from everything I've read over the past couple weeks as though there are good (even great pushing 500 rwhp) ones and bad ones. I'm currently running the canned SCT XF3 economy tune which is by itself without a trailer is a marked improvement. I was screwing around the other day pushing the brake and the skinny pedal at the same time could break the tires loose at 25 MPH (overcame the rear brakes, around 22 psi boost). In reality I was just trying to test the boots on the CAC tubes (after reading reports of blowing boost tubes) before hooking up my camper, didn't expect to break the tires loose. I'm gaining confidence in applying a higher HP tune, just don't want to push it too far and screw up my summer camping season. by breaking the truck.
post #8 of 8 Old 05-23-2013, 06:24 PM
allprodiesel's Avatar
Here's some more reading for you.
How far on stock head bolts?
03 6.0L F-350 ECLB 4WD 240k on the clock
Warren Diesel 175/75s, Regulated Return, MTW Stage II,
5in MBRP, EGR Delete, PHP Tuning and FICM Tuning,
APD Traction Bars, 35's, and groceries in the bed...
Trying to see how long the stock head bolts last...
Also have a 99 7.3 with the motor tore down, gettng some more goodies. It made 507/1130 on stock turbo and tranny
allprodiesel is offline
