Best FICM ? - Ford Powerstroke Diesel Forum
post #1 of 15 Old 05-22-2013, 04:27 PM Thread Starter
585Amarillo's Avatar
Best FICM ?
my FICM is on its way out , I was just wondering whats the best one, New stock, Swamps 58v, bullet proof diesel 4 or 6 phase?
K&N Intake
MBRP 4" Turboback
Silverline 6" Black Aussie Stacks
Zoodad Mod
Ford Updated parts
BPD FICM
Blue Fuel Pressure Spring
ARP Head-studs
Stock Injectors?
AirDog 165 Fuel pump
EGR Delete
SCT Custom Tuner By Inovative Diesel 5 tunes
10" Lift
37" Toyo Open Country M/T
4.56 Gears
18" XD Thump Black Wheels
6.4 Banjo Bolts
Revised Ford Parts
Custom sound system
Glowshift Gauges Trans.Temp., EGT, Fuel Pressure
585Amarillo is offline
post #2 of 15 Old 05-22-2013, 04:38 PM
Quoted: 2 Post(s)
I prefer the BPD 4-phase w/tunes but that's just me.
Troy K.
2003 Ford F-250 6.slow w/240K
4" Turbo back exhaust
SCT X4
XDP coolant filter
Blue Spring
315/75 BFG MT's on American Racing rims
Leveled
5100's
And way more time and money invested than its worth
Turk.919 is offline
post #3 of 15 Old 05-22-2013, 04:50 PM
BACKYARDIGAN
windrunner408's Avatar
Quoted: 4 Post(s)
The BPD unit is just a power supply and shell. It is not a complete FICM, but it will use the logic side of your old FICM. It is tough to say whether or not you have that going out on you. If it were me and I had the money, I would buy a new remanufactured stock FICM, use your old one for the core charge, buy a BPD power supply, and get a FICM tune. Then you would have the most bullet proof FICM out there IMO.
Nate
2006 F350 (BACKYARDIGAN) - 67mm Turbo, 215/85 injectors, WPE intake manifold, NB/Warren Trans, and more stuff that I don't care to mention....
2006 F250 (LITTLE DURTY) - WPE Manifold, Up-pipes, EGR delete kit, and Tuned By ME
BULLET PROOF DIESEL 1-888-967-6653
KC TUROS - Not just a modified Powermax...
WINDRUNNER PERFORMANCE ENGINEERING
windrunner408 is offline
post #4 of 15 Old 05-22-2013, 04:52 PM Thread Starter
should i just test the voltage on the ficm?
K&N Intake
MBRP 4" Turboback
Zoodad Mod
Ford Updated parts
BPD FICM
ARP Head-studs
Stock Injectors?
EGR Delete
10" Lift
4.56 Gears
6.4 Banjo Bolts
Revised Ford Parts
Custom sound system
post #5 of 15 Old 05-22-2013, 06:22 PM
04cr450's Avatar
I vote BPD ficm.. I have the 48v model and performs well but im a little concerned that it never has hit 48v... no other issues with truck either... Guess thats just the way it is
Late 04 f350 lariat.
bpd
marty's regulated return
205/75 injects from holder's
WPE stage 3 ported intake
64.5 borg warner fmw ,compounds in the works now! Comp turbo set up
Warren comp trans
all the typical mods
Big thanks to Dale! The man is a true professional
04cr450 is offline
post #6 of 15 Old 05-22-2013, 06:28 PM
How do you know yours is going out if you haven't checked the voltage?
2005 - Excursion - Eddie Bauer - 4x4
185amp DC Power Engineering alternator
BPD oil cooler and cold weather package
Updated standpipes and dummy plugs
Edge Insight CTS with fuel pressure
No more STC fitting in the HPOP
Updated fuel pressure spring
Updated turbo oil drain
Updated turbo oil feed
Sinister Coolant Filter
BPD 58V FICM
Dual Batteries
Rotella T6
CAT ELC
The best 6.0 advice I've ever seen...
Fishermedic is offline
post #7 of 15 Old 05-22-2013, 06:34 PM
MrOneEyedBoh's Avatar
Quoted: 13 Post(s)
Feedback Score: 11 reviews
Interesting.. Will the Truck show it? and Im guessing you mean the 58v? Because stock is 48v right? well mine shows 48-49.5
MrOneEyedBoh is offline
post #8 of 15 Old 05-22-2013, 06:35 PM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
Feedback Score: 10 reviews
This, however that isn't the most cost effective route lol.
No worries, my old BPD 4 phase 48v usually sat right at 47.5 98% of the time with maybe a .5% chance of hitting 47 and 1.5% going to 48.
This^^.
l BRYAN l
COMPIGNTECH .COM
Look us up on Facebook
COMPRESSION IGNITION TECHNOLOGIES
l 2005 l Ford F250 l FTX l
[A Few Odds-N-Ends]
Tuscany is offline
post #9 of 15 Old 05-22-2013, 06:46 PM
Powerstroke Techie
Quoted: 13 Post(s)
Garage
Feedback Score: 4 reviews
It isn't always a voltage concern that is an indication of ficm failure. I've got one right now that is throwing all injector circuit low codes when cold but the m_pwr is always 48.50-49.00v. even warmed up it's still throwing #1 low all the time. I wouldn't trust just a half shell for a concern like that, you're bound to get burned eventually.
-Matt
Ford Senior Master Tech
2015 F-250 XLT 6.7L
2006 F-250 6.0L SOLD
sinner6.0L is offline
post #10 of 15 Old 05-23-2013, 01:34 PM
Quoted: 2 Post(s)
So what do you think it could be? My truck is throwing low circuit codes on 2 so I was gonna drop new injectors and a new ficm in
Troy K.
SCT X4
XDP coolant filter
Blue Spring
Leveled
5100's
Turk.919 is offline
