wHATS TRANS FLUID??? - Ford Powerstroke Diesel Forum
post #1 of 34 Old 05-22-2013, 08:21 AM Thread Starter
maddenjr's Avatar
Send a message via AIM to maddenjr
What transmission fluid is everyone running? I have changed mine once with factory LV and i aqm gonna do mine again so just wondering if you guys are using Royal Purple or Ams Oil
Spartan,Afe,Mbrp Delete with duals,Banks Intercooler,Custom CCV Mod,22.5 American Forces,Flo Pro egr delete,Lots of Strobes,Atomic Strobes,5%Tint and 20% Windshield Tint,B&W gooseneck,K3LA Train horns and some other goodies, Head studs and waste gate coming this spring
2001 F350 Flatbed/Car Hauler, Ext Cab,07 Front End w/Cowl Hood,SCT Tuned,MBRP Straight pipe
92 Mustang Lx Hatch X275 Drag Radial been low 7's
03 Cobra with a lil extra boost
maddenjr is offline
post #2 of 34 Old 05-22-2013, 08:27 AM
Motorcraft LV from OReilly's for about $5/qt.
Sent from my LG-VS700 using AutoGuide.Com Free App
Karl and his 2003 6.0
Barefoot Accelerator Pedal
TRICO Force wiper blades
Yellow Military Aircraft Valve Stem Caps
Offensive "Stick Family" Decal
Big Ol'Honkin 1 1/4" Shank Receiver Hitch
WHAT!?! I was trying to list stuff that everyone else
hasn't already listed for their truck!
Karls03 is offline
post #3 of 34 Old 05-22-2013, 08:46 AM
strokin6L's Avatar
Quoted: 4 Post(s)
Cheap 'ol mercon/dexron...the Carquest brand.
2004 F-350 SC 4x4, XLT, 4" dual Magnaflow, AFE intake, No Limit piping, spearco intercooler, water injection, ARP studs, hypemax o-ringed heads, SCT tuned by Innovative Diesel, tuned FICM, Hellman's sump, FASS, Fuelab, regulated return, 190/75 injectors, KC/MTW 68 w/.72ar, suncoast trans w/billet input, edge insight CS with dakota digital gauges, amsoil by-pass, BD exhaust manifolds
strokin6L is offline
post #4 of 34 Old 05-22-2013, 08:54 AM
I've been told that anything other than an LV compliant (there's another acceptable version but I can't remember it right now) is inviting disaster. An Edge programmer helped me smoke one transmission, I'm not willing to roll the dice on this one.
Does anyone else have any experience using Mercon/Dexron in a 5R110?
Karls03 is offline
post #5 of 34 Old 05-22-2013, 09:48 AM
Korx's Avatar
Mercon SP or LV only.
2004 6.0L F-250 XLT - ECSB
CTS SCT
Deleted
Studded
5" Exhaust
175cc Injectors
1995 7.3L 5-Speed F-350 XL Dump
Stock
Korx is offline
post #6 of 34 Old 05-22-2013, 09:56 AM
Aretoo's Avatar
I am running Valvoline Max-Life Dex/Merc. It is LV and SP compatible confirmed by both the label and a call to them. I was able to pick it up at AutoZone for $15 per gallon. Did 3 drains and fills with the last one being a swap to the 08 pan and filter setup along with the epic solenoid upgrade. Not one problem with it since I have done it and it shifts much better now since I have done that.
Hello, my name is Nathan...and I am addicted to my skinny pedal!
2006 F250 Crew Cab Short Bed
Harley Davidson Edition # 01592
MODS
ARP Studs
Edge Insight CTS with EGT
IPR Gen2 EGR Delete
Sinister Coolant Filter
MBRP 4" turbo back
PHP Atlas 40 FICM Tune
Gearhead tunes
Rotella Ultra ELC
Aretoo is offline
post #7 of 34 Old 05-22-2013, 10:50 AM
colonel angus's Avatar
Quoted: 2 Post(s)
Don't believe the Autozone guy that will say Lucas will work since it is in their system as Ford SV compatible. A call to Lucas confirmed my fear, it's not compatible whatsoever.
Mercon LV for the Win.
D
2005 CC SB 147K
MTW MaDmAx 68mm VGT
Warren Diesel 175/75's Super Spools N Drew's Tunes
VXCF9CA TQCI1NB
SCT A101706100004F6C
VIN FTSW21P65EB08535
ARP's - MBRP T-Back Kitty Del.
ICON 4.5" + 2" Spacer
Mickey T's Baja ATZ P3 37's
METHOD Racing Wheels 20x
ScanGauge II / RedHead Box
Snow Perf. Stg. II W/ Banks Intercooler
Bulletproof EGR Del. & External Filter
ELC Coolant & Sin. Coolant Filter
AMP Steps & ARE Cover W/ Bed Slide
colonel angus is offline
post #8 of 34 Old 05-22-2013, 11:30 AM
strokin6L's Avatar
Quoted: 4 Post(s)
Not necessarily.
post #9 of 34 Old 05-22-2013, 11:47 AM
Korx's Avatar
Not necessarily.
Unless he's got a built/rebuilt trans, that is what the manual/ford calls for. I mean you can use whatever you want in your truck but I know my stock 5r110 will only see SP or LV.
CTS SCT
Deleted
Studded
5" Exhaust
175cc Injectors
Stock
Korx is offline
post #10 of 34 Old 05-22-2013, 11:48 AM
2000-7.3L's Avatar
Feedback Score: 10 reviews
What he said!
2000-7.3L is offline
