6.0 run away - Ford Powerstroke Diesel Forum
post #1 of 19 Old 05-21-2013, 02:50 PM Thread Starter
6.0 run away
ok as it states ive been experiencing some some odd issues.... my 05 has a SCT tuner with IDP tow tune and agg, street tune, in tow tune it runs great but in agg, street say on a free rev you rev it up to about 2800 rpms and the sucker screams to a little over 4000RPMS without being in the pedal same as for driving awesome low end power nice and smooth then all of a sudden the trucks takes off like a bat out of hell and will rev way past 4k as in the truck keeps accelerating extremly fast up to 90MPH with maybe 10% throttle pretty scary but on the tow tune its like driving a normal truck just perfect. well i have my custom tunes set for the powermax turbo that im getting at the end of the week but i dont think that could make it do that unless i had sticking turbo vanes maybe over speeding the engine but i dont see over 28psi??? any help would be greatly appreciated. i sent an email to IDP waiting to hear back from them
2005 F250 CCSB
6'' procomp lift
35'' nitto trail grappler MT
ENGINE MODS:
STUDDED-o ringed
EGR cooler delete
SCT tuner gear head SRL+tuned
powermax turbo
Volant cold air intake
AFE bladerunner cold side intercooler pipe
polished alum. intake elbow
MBRP 4" exhaust no muffler or cat 6'' tip
HYDROGEN GENERATOR/INJECTION...yes it works
sinister coolant filter
sinister oil bypass filter
diesel site trans filter
DYNO numbers on stock injectors 498HP/864ftlbs
dieselperformance1 is offline
post #2 of 19 Old 05-21-2013, 03:51 PM
tkobes43's Avatar
Quoted: 2 Post(s)
Garage
Never heard that happening before!! Curious as well.
Tom
5" MBRP Straight Exhaust w/ 6" tip, SCT Monitored, Limo Tints, 20" LED Lightbar, 8k HIDS, & Some other goodies
Other Rides
1978 Trans Am Y88 403 84k original miles
1996 Ford F350 PSD Mason Dump 134k Original Miles!
Gone But Not Forgotten... (Lilah) 2008 Ford F250 Lariat CrewCab
Proud To Be An American!
tkobes43 is offline
post #3 of 19 Old 05-21-2013, 05:06 PM Thread Starter
yeah it scared me lol i was like wtf was that for hahaha but on the custom tow tune its fine but agg. street i cant even drive it, its that bad! starts just fine idles fine takes off fine but soon as you hit the 2600 or so RPM it takes off like a rocket and over revs hardcore and free revs just wants to go right to the rev limiter
2005 F250 CCSB
6'' procomp lift
ENGINE MODS:
STUDDED-o ringed
EGR cooler delete
powermax turbo
post #4 of 19 Old 05-21-2013, 05:09 PM
Bump To Pass!!
toren302's Avatar
Quoted: 1680 Post(s)
Had one do this same thing. It was after we installed a set od Dynomite Diesel stock injectors. Dynomite wont warranty them unless the oil and fuel cleaner they give you with the injectors is used. I followed the directions and put the oil cleaner in the oil and road tested. Exact same situation. Truck would take off and had to hold the brake pedal with both feet at one point. I noticed while this would happen the ICP and IPR were all over the place. Its like the IPR could not do its job. Try monitoring the ICP and IPR and see what it is doing when the issue is occuring.
toren302 is offline
post #5 of 19 Old 05-21-2013, 05:09 PM Thread Starter
just waiting for a reply from erik at innovative. my new turbo will be here friday and when i put it on ill retune it and do a free rev and see if it does it and if it does ima have to have the tune worked with. i hooked up my laptop with fords software from a buddy that works there and every single thing sensors pressures are all in the green so something in the tune that doesnt like me truck i guess which sucks cause it was so awesome but i knew something was wrong so i cant run that file for now till i figure out why its doing it. when i mean rocket i mean 35'' mud tires lit up at 45mph and billowing white smoke behind me lol
2005 F250 CCSB
6'' procomp lift
ENGINE MODS:
STUDDED-o ringed
EGR cooler delete
powermax turbo
post #6 of 19 Old 05-21-2013, 05:10 PM
F250SixOH's Avatar
Does it seem like the trans is slipping maybe thus causing the rpms to spike? Truck wouldn't be accelerating normally though. My Xtreme Street definitely can be like a switch as far as the power sometimes. Not as dramatic as you are talking about but there is a sweet spot in the pedal where it just wants to get up and run!
F250SixOH is offline
post #7 of 19 Old 05-21-2013, 05:11 PM Thread Starter
i have the edge insight CTS i can monitor the ICP what would i be looking for exactly
2005 F250 CCSB
6'' procomp lift
ENGINE MODS:
STUDDED-o ringed
EGR cooler delete
powermax turbo
post #8 of 19 Old 05-21-2013, 05:12 PM
Powerstroke Techie
Quoted: 14 Post(s)
Garage
Feedback Score: 4 reviews
I've wondered about these tunes tricking ICP into reading much less than it actually is. You're trying to reach a desired ICP at WOT the PCM is thinking it's much less than it actually is. When you close that IPR off the engine will rev up on it's own.
-Matt
Ford Senior Master Tech
2015 F-250 XLT 6.7L
2006 F-250 6.0L SOLD
sinner6.0L is offline
post #9 of 19 Old 05-21-2013, 05:13 PM Thread Starter
i dont think its the trans casue the power goes kinda flat then like i hit nitrous and shes gone doing 80 MPH ++
2005 F250 CCSB
6'' procomp lift
ENGINE MODS:
STUDDED-o ringed
EGR cooler delete
powermax turbo
post #10 of 19 Old 05-21-2013, 05:17 PM Thread Starter
yeah it doesn't rev up slow like a free rev you can hit the throttle and say it would go just past 2800rpm and it just speratically revs to 4000+ rpms
2005 F250 CCSB
6'' procomp lift
ENGINE MODS:
STUDDED-o ringed
EGR cooler delete
powermax turbo
