Turbo for 225s - Ford Powerstroke Diesel Forum
post #1 of 39 Old 05-21-2013, 02:07 PM Thread Starter
Turbo for 225s
So I'm beginning the plunge to mod the truck and need some opinions on matching a turbo(s) with 225's. I'm debating large VGT vs large single non VGT with some divided up pipes. I don't think I've got the cash to do compounds now, but if I go non VGT I'd like to have that turbo be ideal for a HP later. This is assuming the supporting mods are done of course. Also a little concerned about HPO as well with the 225s. Thanks guys
2016 F250 Lariat
the06wildebeast is offline
post #2 of 39 Old 05-21-2013, 03:00 PM
snopro_03's Avatar
You can pick up a boxed 366 for around 650.00$ and cutting edge diesel makes a nice set of divided up pipes for another 600.00$. Would be a pretty cost effective set up vs a big vgt and net you around 600ish horse with your injectors. Can't beat the sound of a non vgt 6.0 either. This turbo could be used later if you wanted compounds.
Chad
2003 6leaker
N.E.W 2.5 Truck
snopro_03 is offline
post #3 of 39 Old 05-21-2013, 03:01 PM
stroke of luck's Avatar
a 66 with divided t4 housing and divided uppipes would be perfect for 225's (assuming you maintain hpo)
2005 CC FX4. Cutting Edge Diesel Compounds and everything else that goes with them.
stroke of luck is offline
post #4 of 39 Old 05-21-2013, 03:07 PM Thread Starter
Would a 66 move enough air for 225s? or would 205s better match the 66?
2016 F250 Lariat
post #5 of 39 Old 05-21-2013, 05:41 PM
205's and a 66 would be a fun, reliable street combo that will still work on stock oil and be significantly less expensive than some of the other options out there.
post #6 of 39 Old 05-21-2013, 06:26 PM Thread Starter
Thanks. Got any ideas of where to start looking for a turbo and a set of T4 up pipes?
2016 F250 Lariat
post #7 of 39 Old 05-21-2013, 07:22 PM
pizza pig's Avatar
225s are too much fuel for a 66 on full fuel and maintaining icp. But that setup is good for 650 if you can maintain injection pressure. I have fuel pulled in my setup (225/100, 66 with ced pipes) on the brink of dropping icp.
pizza pig is offline
post #8 of 39 Old 05-21-2013, 07:46 PM
shoot me or 06powerstroke06 a pm. I know where you can get fixed up.
post #9 of 39 Old 05-22-2013, 06:58 AM Thread Starter
^^ Will do. Pizza how did your 205/150s do with a 66? I remember you had that set up. And how much fuel you have pulled on your 225s? I'm guessing your still on stock HPO. Thanks guys for the help.
2016 F250 Lariat
post #10 of 39 Old 05-22-2013, 07:58 AM
kdogg85's Avatar
205's will do fine with a 366, just stay 100% or less on the nozzle size. I think Greg stated 150's fogged pretty bad, if I'm wrong, sorry Greg.
If a second charger is what you want and it's gonna be soon, just get a 364 and a reduced fuel tune to get you by. Then lay a 480 or 483 downwind of it and have some real fun.
David
05 f250 ( double your pleasure ) underway
'10 f250 ccsb 4x4, project super mom 366/515 compounds, 200hp sticks, and all the other goodies
Most importantly, the car seat mod
kdogg85 is offline
