removing the 6 gun - Ford Powerstroke Diesel Forum
post #1 of 5 Old 05-20-2013, 06:13 AM Thread Starter
bigz's Avatar
removing the 6 gun
I am trying to remove the 6 gun system from my truck... i have the directions but where it says remove the wires that splice into the factory harness with a t-tap i cant find those wires am i missing something... this system has the speedloader does this have anything to do with it?
2005 King Ranch
arp head studs
bpd egr cooler
magnaflow duals
airaid intake
Looney tune by Vivian
edge cs monitor
xdp coolant filter
bigz is offline
post #2 of 5 Old 05-20-2013, 06:52 AM
Quoted: 3 Post(s)
I think you're talking about the harness under the hood. The Banks system typically bypasses the stock harness with their equipment.
11 F250 CCSB King Ranch
Tyrant tunes, No Limit Stage 2, No Limit Block Off, 5" exhaust, CTS
2.5" Carli Commuter, 4.5" PMF block, 37x12.5R20 Toyo RTs, Stock wheels
01 Ex 7.3l Limited
Swamps tunes, 6637, 4" exhaust, 6.0 trans cooler, Hellwig rear swaybar, CTS
06 headlights
bigred3297 is offline
post #3 of 5 Old 05-20-2013, 07:11 AM Thread Starter
bigz's Avatar
My factory harness hooks to the banks module then their harness from the banks module to your pcm where the factory harness was hooked... but there are supposed to be 2 or 3 single wires connected to the wires in your factory harness that goes to the banks harness i dont see those on my truck
2005 King Ranch
arp head studs
bpd egr cooler
magnaflow duals
airaid intake
edge cs monitor
xdp coolant filter
bigz is offline
post #4 of 5 Old 05-20-2013, 10:20 AM
PowerStrokedRedneck's Avatar
If there aren't single wires tapped into the other two PCM harness, then there is probably an OBD-II plug under the dash.
Sent from AutoGuide.com App
PowerStrokedRedneck is offline
post #5 of 5 Old 05-20-2013, 10:51 AM Thread Starter
bigz's Avatar
yep there sure is... i didnt know that made a difference... thanks
2005 King Ranch
arp head studs
bpd egr cooler
magnaflow duals
airaid intake
edge cs monitor
xdp coolant filter
bigz is offline
