6.0 boost guage?
My buddy just got a 03 6.0. Im not real familier with the 6.0, where is the best place to hook the boost guage at?
Thanks for your help. |
If its a mechanical gauge, drill and tap the intake elbow right in front of the oil & fuel filter, front side top of engine valley.
I agree, I just installed mine yesterday and it was very simple to drill and tap the elbow. The only thing I had trouble with was getting the plastic tube hooked back up to the elbow when I re-installed it. It definitely takes a lot of persuasion to get it back on.
drill and tap the intake elbow in front of the filters, as mentioned prior.
![]() make sure to take it off first however, shavings in the intake manifold would obviously not be the best thing. those oval shaped ferrules can be a PITA, i swapped mine out for a different style fitting at a shop around the corner. good luck |
