injector size? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 05-19-2013, 06:23 PM Thread Starter
585Amarillo's Avatar
Talking injector size?
I purchased another 6.0 and it had a few things done to it i installed the sct tuner and its putting out a ton of smoke i was just wondering if there is a way to tell the size of it if i took it out.
K&N Intake
MBRP 4" Turboback
Silverline 6" Black Aussie Stacks
Zoodad Mod
Ford Updated parts
BPD FICM
Blue Fuel Pressure Spring
ARP Head-studs
Stock Injectors?
AirDog 165 Fuel pump
EGR Delete
SCT Custom Tuner By Inovative Diesel 5 tunes
10" Lift
37" Toyo Open Country M/T
4.56 Gears
18" XD Thump Black Wheels
6.4 Banjo Bolts
Revised Ford Parts
Custom sound system
Glowshift Gauges Trans.Temp., EGT, Fuel Pressure
585Amarillo is offline
post #2 of 6 Old 05-19-2013, 07:06 PM
04cr450's Avatar
no but usually the nozzles will have a number on it telling you what size nozzle you have.
Late 04 f350 lariat.
bpd
marty's regulated return
205/75 injects from holder's
WPE stage 3 ported intake
64.5 borg warner fmw ,compounds in the works now! Comp turbo set up
Warren comp trans
all the typical mods
Big thanks to Dale! The man is a true professional
04cr450 is offline
post #3 of 6 Old 05-19-2013, 07:16 PM
Chatham036's Avatar
Quoted: 134 Post(s)
Could it be the custom tunes you decided to run on the device?
If you would like, we will take the time to write you a couple tunes to dial in for unknown size injectors.
Comments or opinions expressed by me do not necessarily represent the views of PHP, its management, nor its employees. PHP is not responsible for, and disclaims any and all liability for the content of comments written by me.
Chatham036 is offline
post #4 of 6 Old 05-21-2013, 03:55 AM Thread Starter
I have inovative sct with anarchy, street, performance, tow, economy , stock the first three smoke a ton all way through I was thinking p-max turbo 68mm, or mtw turbo
K&N Intake
MBRP 4" Turboback
Zoodad Mod
Ford Updated parts
BPD FICM
ARP Head-studs
Stock Injectors?
EGR Delete
10" Lift
4.56 Gears
6.4 Banjo Bolts
Revised Ford Parts
Custom sound system
post #5 of 6 Old 05-21-2013, 06:12 AM
Adamv7010's Avatar
All of Eric's tunes are Smokey on my trucks
Adamv7010 is offline
post #6 of 6 Old 05-22-2013, 04:17 PM Thread Starter
I'm going to be pulling top of engine apart this week for egr delete so ill pull out a injector to see whats in there.
K&N Intake
MBRP 4" Turboback
Zoodad Mod
Ford Updated parts
BPD FICM
ARP Head-studs
Stock Injectors?
EGR Delete
10" Lift
4.56 Gears
6.4 Banjo Bolts
Revised Ford Parts
Custom sound system
