Banks intercooler pressure test. - Ford Powerstroke Diesel Forum
post #1 of 6 Old 05-18-2013, 07:48 PM Thread Starter
Sesco4's Avatar
I bought a used banks intercooler and want to have it pressure tested. I figure I will take it to the local radiator shop to have it tested but have no idea what to tell them to test it at. Looking for advice so they don't blow it up.
Thanks
2005 F250 CCSB 4X4
PHP Atlas 40 FICM Tune
PHP ECM/TCM Rollback
Old ECM VXCF9N4
New VXCF4N3
Old TCM TQCI1NA
New TQCI0N3
Zoodad Mod
Delo ELC Coolant
Rotella T6 w/Rev-X
Fumoto Valve F-111
2009 Rear Bumper
Newton Lifts 2.5" leveling kit
Sesco4 is offline
post #2 of 6 Old 05-18-2013, 08:19 PM
Term3's Avatar
Phone Banks up and ask what they test it at instead of having some know it all give you the wrong information.
Sent from AutoGuide.com App
SCT, no studs...yet, Dual OEM intake air filter housings, Banks intercooler & intake elbow, Banks exhaust system, Windrunner ported intake manifold, Bullet Proof Diesel remote oil cooler & thermostat, AirDog2 (plus a couple spares), Power steering filter (Amsoil dual-bypass), MagTec deep ATF pan, Electric oil pre-lub pump, Dakota Digital gauges.
Term3 is offline
post #3 of 6 Old 05-18-2013, 08:31 PM
portcity_gt's Avatar
Quoted: 1361 Post(s)
As low as 5-10 psi will clearly show even the smallest of leaks.
03 cclb dually,6.0,arp studs,bpd oil cooler,bpd 6 phase ficm,bpd water pump,bpd all aluminum cac,all aluminum radiator,amsoil bypass oil filter,ipr high flow coolant filter,egr delete,livewire ts tuned by Vivian & tony,php ficm tuner,dc power 300-spx,Detroit trutrac,6" dual side pipes,07 front end,custom front bumper,shaved badges,led button roof lights,08+ mirrors,12 tailgate,13 rear bumper,13 tail lights,dropped I beams,custom rear 4 link w/bags,k5la train horn,24" alcoa's.
portcity_gt is offline
post #4 of 6 Old 05-18-2013, 08:57 PM Thread Starter
Sesco4's Avatar
Both responses make sense.
Thanks guys
2005 F250 CCSB 4X4
Old ECM VXCF9N4
New VXCF4N3
Old TCM TQCI1NA
New TQCI0N3
Zoodad Mod
Delo ELC Coolant
Rotella T6 w/Rev-X
Fumoto Valve F-111
2009 Rear Bumper
Sesco4 is offline
post #5 of 6 Old 05-19-2013, 07:15 PM
Chatham036's Avatar
Quoted: 136 Post(s)
Personally, I would pressure test 5 lbs over what you intend on pushing for boost.
I.e. if your truck typically runs 32 lbs of boost, test at 37 lbs.
You won't balloon and rupture an aluminum radiator at 40 lbs of pressure so long as there are no defects
Comments or opinions expressed by me do not necessarily represent the views of PHP, its management, nor its employees. PHP is not responsible for, and disclaims any and all liability for the content of comments written by me.
Chatham036 is offline
post #6 of 6 Old 05-20-2013, 04:40 PM Thread Starter
Sesco4's Avatar
I talked to a tech at Banks today and he recommended 40 psi.
2005 F250 CCSB 4X4
Old ECM VXCF9N4
New VXCF4N3
Old TCM TQCI1NA
New TQCI0N3
Zoodad Mod
Delo ELC Coolant
Rotella T6 w/Rev-X
Fumoto Valve F-111
2009 Rear Bumper
Sesco4 is offline
