in the process of installing sump. need help - Ford Powerstroke Diesel Forum
post #1 of 8 Old 05-18-2013, 01:03 PM Thread Starter
steelnc's Avatar
I'm in the process of installing a sump and have a few questions. Already drained the fuel and installed the sump. (beans diesel) I'm running a AD 2 btw. Do I need to drop the tank to disconnect the supply line? It's tucked up between the frame and the fuel tank tight. How do I block off the line once disconnected? Tried searching for detailed installs but couldn't come up with anything. Any help would be much appreciated. Pics would be good too. Thanks for any help in advance.
2014 F250 Platinum
4" Pure Performance lift
20x10 Novas 35" Toyos
Mini Max
5" Flo pro
steelnc is offline
post #2 of 8 Old 05-18-2013, 01:07 PM
the chad's Avatar
I just abandoned that line and put a bolt inside it with a hose clamp.
Chad
07 F250
4'' MBRP to 7'' FTE Miter
ELC w/ Sinister Coolant filter
ARP's with OEM
Edge CS and Trans, Boost, FP on the pillar
Voltmeter in dash
Banjo's
Looney
Cal-Tracs
20x10 Monsters wrapped in 305 420s
RCD Egr Delete
Warren 190/75
Dozers RR
MTW Stage 2
557 hp/1206 ft/lbs
Big thanks to JJ @ Dozers And Adrian at MTW
the chad is offline
post #3 of 8 Old 05-18-2013, 01:09 PM
04cr450's Avatar
If the tank is empty just lower the tank enough to get your hands in there.... Piece of cake. use 2 jack stands and a jack. Easy peasy..
Late 04 f350 lariat.
bpd
marty's regulated return
205/75 injects from holder's
WPE stage 3 ported intake
64.5 borg warner fmw ,compounds in the works now! Comp turbo set up
Warren comp trans
all the typical mods
Big thanks to Dale! The man is a true professional
04cr450 is offline
post #4 of 8 Old 05-18-2013, 01:12 PM Thread Starter
steelnc's Avatar
Is there enough slack on the fill tube to keep it connected? How do I go about blocking off the supply line to the tank?
2014 F250 Platinum
Mini Max
5" Flo pro
steelnc is offline
post #5 of 8 Old 05-18-2013, 05:11 PM Thread Starter
steelnc's Avatar
Finished it up a lil while ago. Used a 3/8 compression fitting with a male adapter and a cap to block off the line from the tank. Thanks for all of the help guys. Took way too long from start to finish but i'm guessing it's about a 30 minute job once all the fuel is drained. Wasn't that bad looking back on it. Just didn't know what the hell I was doing. Lol. Thanks again.
2014 F250 Platinum
Mini Max
5" Flo pro
steelnc is offline
post #6 of 8 Old 05-18-2013, 08:37 PM
04cr450's Avatar
Hope my advice helped you out a little bit in the pm....Glad u got it completed
bpd
Warren comp trans
04cr450 is offline
post #7 of 8 Old 05-18-2013, 08:40 PM
Powerstroke Techie
JUGERNAUT's Avatar
Quoted: 3 Post(s)
Feedback Score: 13 reviews
Nice job fellows!
2001 to 2015 SENIOR MASTER TECHNICIAN
BEEN WITH FORD 27 YEARS:
PROUD NAVY VET= ANTI SUBMARINE WARFARE
A/C ASW A/W WINGS
2003 F250 AND I HATE IT. IT ROBS ME BEFORE I GET TO BANK!
JUGERNAUT is offline
post #8 of 8 Old 05-19-2013, 04:08 AM Thread Starter
steelnc's Avatar
Helped a lot. Thank you.
2014 F250 Platinum
Mini Max
5" Flo pro
steelnc is offline
