BPD FICM - Ford Powerstroke Diesel Forum
post #1 of 14 Old 05-18-2013, 09:15 AM Thread Starter
BPD FICM
First off, I have searched for a thread and can't find a straight answer, if you know a thread with a direct answer please send it to me.
I have a '06 6.0 dually that I have stock injectors. I have done the blue spring upgrade and ran an Edge platinum since the truck was new. I tow a 20,000# trailer some, like twice a year, and use my 1 ton as a work truck.
Other upgrades:
Bypass filter on oil and coolant
MBRP turbo back 4"
Replaced the rotors and front bearings
I understand the increased charge to the injectors, but is there any need to run the 54 or 58 and will this extra kick fry the stock injectors or other parts?
The BPD is the six phase four screw, if that changes anything.
Thanks for any help!
Suprob is offline
post #2 of 14 Old 05-18-2013, 10:29 AM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
Feedback Score: 10 reviews
I am running the 6 phase BPD FICM set on 58v. I noticed on mine cold starts were faster and smoother and there was a noticeable difference in bottom end throttle response.
The OEM style FICM's that were set to 58v would try the FICM boards because they weren't designed to handle that much current. The BPD is a completely redesigned custom board made to withstand that current flow and the abuse we put on our trucks. I you get the 6 phase FICM I wouldn't hesitate to run it on 58v if I were you. Just my $0.02.
l BRYAN l
COMPIGNTECH .COM
Look us up on Facebook
COMPRESSION IGNITION TECHNOLOGIES
l 2005 l Ford F250 l FTX l
[A Few Odds-N-Ends]
Tuscany is offline
post #3 of 14 Old 05-18-2013, 10:52 AM
ZMANN's Avatar
Quoted: 1343 Post(s)
I run the BPD 6 phase 58v and noticed no difference between that and my barley failing OEM other than I get a code for FICM voltage out of range
been running it a year with no injector issues
if I ever have it out I am going to reset it to 48 since BPD seems to have added a disclaimer on the overvoltage since I bought mine and I don't like having a code present
We Miss you Ronnie
ZMANN is online now
post #4 of 14 Old 05-18-2013, 11:08 AM
Suck, Squish, Bang, Blow!
dfuzz78's Avatar
Hmmm... That is interesting.
I had to go look that up, and when I did, I saw they make them in blue now!
Now I want a blue one!
Anyone wanna swap anodized aluminum for anodized blue...? JK
Denis "Lt. Sled"
2006 F-350 Crew Cab Long Bed Dark Shadow Gray
462hp / 927ft-lbs Corrected
ARP Head Studs, NUC Motorsports Oil Bypass, CFM+ Intake Elbow, Wicked Wheel 2
Bullet Proof Diesel FICM w/Atlas 40, SCT SF3 w/SPD by TSD! Grover Fire Truck Horns
Cab Light Mod, Blue Spring Mod, Zoodad Mod, High Idle Mod, Lost EGR Mod
dfuzz78 is offline
post #5 of 14 Old 05-18-2013, 11:08 AM Thread Starter
How hard is it to "switch" between the output? It seems like you are cutting wires. Is that not correct? Either way thanks for the speedy replys. I have been w/o my truck since last Sat. And the part is due on today. I got to get back in "my" truck.
Suprob is offline
post #6 of 14 Old 05-18-2013, 11:09 AM Thread Starter
I am hoping for a blue one also, but the six phase was only listed in black.
Suprob is offline
post #7 of 14 Old 05-18-2013, 11:13 AM
sprksonu's Avatar
i believe they only come in black now like the water pumps i may be wrong though
WRECKED EM DAMN NEAR KILLED EM!
2005 f250 ccsb 4x4 Studded, 03 turbo w/billet wheel, AFE stage2, 5"diamond eye, BPD egr cooler & "NEW" external oil cooler, BPD 48v FICM, BPD water pump, BPD aluminum radiator, 6.4 banjo's, blue spring, HFCM e-z drain, riff raff boots, gearhead srl tune , PHP FICM tune, sct livewire 5015, updated stc, updated stand pipes & dummy plugs, updated oil feed & drain, Zerex ELC coolant, Pro Comp 6" lift, 325/70/17 Toyo open country at
sprksonu is offline
post #8 of 14 Old 05-18-2013, 11:14 AM
dfuzz78's Avatar
Yes, you cut one wire for 58 volts or the other wire for 52 volts.
Cutting both wires will make the FICM 48 volts.
If you do not cut any wire, it will remain 48 volts from BPD...
But why would one buy the 58 volt version and not cut the 58 volt wire?
I have a beta test unit that was 48 volts and I'm happy.
Denis "Lt. Sled"
dfuzz78 is offline
post #9 of 14 Old 05-18-2013, 11:27 AM
portcity_gt's Avatar
Quoted: 1188 Post(s)
Mine is set on 58v simply because it was set up that way when I got it. I haven't had any issues from the increased voltage.
But if you have your doubts about the higher voltage you can just buy the four phase and save yourself a couple hundred bucks. Even their four phase is light years above the oem ficm.
03 cclb dually,6.0,arp studs,bpd oil cooler,bpd 6 phase ficm,bpd water pump,bpd all aluminum cac,all aluminum radiator,amsoil bypass oil filter,ipr high flow coolant filter,egr delete,livewire ts tuned by Vivian & tony,php ficm tuner,dc power 300-spx,Detroit trutrac,6" dual side pipes,07 front end,custom front bumper,shaved badges,led button roof lights,08+ mirrors,12 tailgate,13 rear bumper,13 tail lights,dropped I beams,custom rear 4 link w/bags,k5la train horn,24" alcoa's.
portcity_gt is online now
post #10 of 14 Old 05-18-2013, 11:39 AM
sprksonu's Avatar
i have the 4 phase it runs at 49-49.5 volts all day great unit.
sprksonu is offline
