Finishing up Monitoring (fuel pressure in particular) - Ford Powerstroke Diesel Forum
post #1 of 4 Old 05-17-2013, 09:50 PM Thread Starter
Question Finishing up Monitoring (fuel pressure in particular)
To start out, I've currently got installed an Edge Insight CS with the EAS starter kit and the EGT with the expandable option to hopefuly add fuel pressure.
I've been researching various options with regards to adding fuel pressure to my existing cluster. Near as I can deduce I've got 2 options.
(1) Use the Edge Option: which includes the EAS pressure sensor with the EAS universal sensor input and uses one of the
(2) EAS Universal Sensor input with a generic pressure transducer (possibly ... Pressure Transducer or Sender 100 PSI for Oil Fuel Air | eBay)
Is there something I'm missing or is option 2 not the much less expensive solution? Hope I'm not potentially stepping on site sponsors toes with an ebay item.
tclint1981 is offline
post #2 of 4 Old 05-18-2013, 03:44 AM
Motor Head.
robertc68's Avatar
Quoted: 39 Post(s)
I did option 1.
04 350 DRW CC LB,4:10,245/75/17,tires 4X4..Coolant filter. CTS.Stage II AFE.EGR Delete,Zoodad ,regulated return, ,Arp,OemHG,AD150,WPE ported int,58FICM,190/30 Injec,05 coil conversion.WPE/KC 1.5 turbo,2011 rear leafs,13 tailgate,flight fab trac bars.2014 Power/folding/Extend mirrors.
robertc68 is offline
post #3 of 4 Old 05-18-2013, 07:43 AM
twoicebergs's Avatar
Quoted: 43 Post(s)
The pressure sensor you linked is very good and for the price, it can't be beat. There is a reason why he has sold almost 1000 of them. In any case, don't over think it, pick one and get it done.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #4 of 4 Old 05-18-2013, 02:39 PM Thread Starter
Thanks for the input. I know which way I'm going to go.
Tags
eas , fuel pressure
