FBD Exhaust keeps moving - Ford Powerstroke Diesel Forum
post #1 of 33 Old 03-04-2008, 09:35 AM Thread Starter
smuesse's Avatar
Any one had any trouble keeping there FBD Exhaust still. I keep having to adjust it to keep it off the firewall. This will be the third time to have to do this. I take it all loose, shove someting inbetween the DP and the firewall and start tightening from the back to the front. I noticed this past weekend that it has moved again and is just close enought to bump the firewall when i hit bumps. Is there a better way to hold it firmly in place. I have the 4" turbo back. Thanks
Scott Muesse
Hubbard Texas (Near Waco)
1999 F-350 7.3 4x4 CCLB
2015 Palomino Puma 30-RKSS
'73 F-100 Restoration Project
'05 ClubCar gas golf cart
smuesse is offline
post #2 of 33 Old 03-04-2008, 09:44 AM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 20 Post(s)
I have never dealt with FBD so I'm not sure. I have the Silverline 4" turbo back and have never had a problem with anything coming loose. Are the clamps regular exhaust clamps or band clamps? I know I had to tighten mine a few times right after I put it on because the regular style clamps would be loose after heating up and cooling down, but no problems since and never had a problem with it moving.
dhanna6powerstroke is offline
post #3 of 33 Old 03-04-2008, 09:54 AM Thread Starter
smuesse's Avatar
They are the regular clamps. Im tempted to weld it but i dont want to find out it is still going to move and i have to grind off the welds.
Scott Muesse
smuesse is offline
post #4 of 33 Old 03-04-2008, 09:58 AM
Mod Newbie
Quoted: 20 Post(s)
I would just loosen everything up again, get it where you want it, tighten the clamps and then just tack weld each joint (1 tack weld on each side of connection). That way if it moves it won't be a big deal to grind them down. Also when you tighten your clamps, take a hammer and hit the clamp to try and seat it better on the exhaust and tighten it again. Hopefully this will help.
post #5 of 33 Old 03-04-2008, 10:06 AM
KVFD
redstroker_2002's Avatar
is fbd good or not cuz i was going to order some 4 inch
-Josh
2008 2500 LMM- Deleted, Blocked, Fueled, & Tuned by:
redstroker_2002 is offline
post #6 of 33 Old 03-04-2008, 10:07 AM
Mod Newbie
Quoted: 20 Post(s)
I like my Silverline exhaust real well. Very well built and everthing goes right in place and utilizes the factory hangers.
post #7 of 33 Old 03-04-2008, 10:14 AM Thread Starter
smuesse's Avatar
I like my FBD, i just need to get it adjusted. Thanks for the tips Dhanna.
Scott Muesse
smuesse is offline
post #8 of 33 Old 03-04-2008, 10:23 AM
Mod Newbie
Quoted: 20 Post(s)
No problem. Hope you get it fixed. Let me know how it goes.
post #9 of 33 Old 03-04-2008, 10:29 AM
SMOKE ROLLER
Rescuediver's Avatar
I've got MBRP and had the same problem, but only under WOT. I used some header tape and aluminum cable ties and pulled it towards the frame and away from the tranny lines & cab. Never had a problem since doing it. I'll get some pix tommorrow if you like. It's just raining like heck today...
TERRY
BIG RED - SOLD
4" SILVERLINE TB
SCT w/Edge INSIGHT
6" Superlift w/ 37" TOYO'S on 20's
Accufab Elbow
Lots of Recon Lights
HID Headlights & Foglights
Train Horns
SNOW H2O/Meth
Rescuediver is offline
post #10 of 33 Old 03-04-2008, 02:14 PM Thread Starter
smuesse's Avatar
Thanks Terry, pics would be great. Is there are torq spec on the Clamp from the DP to the Turbo. Seems like i could move the DP slightly when i pushed on it.
Scott Muesse
smuesse is offline
