Oil temp and coolant temp sending units - Ford Powerstroke Diesel Forum
post #1 of 10 Old 05-17-2013, 12:39 AM Thread Starter
mrc228's Avatar
Just got some new gauges for my truck. I need to add sending units for oil and coolant temp. I've read in a few places that the coolant temp can go in the drivers side plug accessed from under the truck. Where can I get a plug with the 1/8" npt fitting? My plug has an Allen key fitting for removal so I can't just drill it out. Would putting it on the spare port on my coolant filter work just as well?
Also, I have no idea where I can add the oil temp sender?? Can it be mounted on top of the oil filter cap? I've seen some pics of a sensor mounted here on a billet style cap but A. I'm not sure about an aftermarket cap and B. I'm not sure if its a temp or pressure sender that I'm looking at.
'06 F250 CC FX4 - 127k miles
Under the hood
EGR Delete, Upgraded oil cooler, upgraded stc fiting /w new HPOP, Blue Spring, 4" Turbo Back, SCT tuner /w Wildman Extreme & Street tune, Sinister Diesel Coolant Filter
studs to come
In the cab
Pillar Glowshift gauge package (EoP/Fuel press/EGT), Dashboss
Alpine touchscreen nav head unit, bluetooth, Phoenix Gold 4-channel amp, JL Audio's 6.5 components up front, 5x7's in rear doors, 10" sub behind seats.
mrc228 is offline
post #2 of 10 Old 05-18-2013, 01:25 AM Thread Starter
mrc228's Avatar
So, after googling and looking around at other forums, I finally found the right billet oil filter cap. Got it, and the fuel filter cap both on order (got the fuel filter cap so they'd match.. might add fuel pressure later). Going to add the EOT sender to the top of it once it arrives. For the ECT I still haven't found the plug /w 1/8" npt fitting I need on the engine block. I decided to try the sending uinit on the free port at my coolant filter. Drove around for a while comparing the reading on the glowshift gauge to the reading from my SCT tuner.. At first they were as close to one another as you could ask for, all the way up to about 180 deg f. After a few hard runs, the SCT was showing 190-192 on the coolant temp, and the glowshift gauge was still only showing 180-185 tops. I'm thinking this is due to the fact that the coolant filter is only a partial bypass, and therefor isn't getting the full flow and heat to give me a true reading. Before I move the sender to the block location, I'm going to try changing the coolant filter and see if I get a little better flow and a more accurate reading. I added it right after I got the truck, and had a new oil cooler installed about to 3 months ago.
Here's a few pics so far:
Other than wire strippers and crimpers, the only tools Ive needed are listed below.
EGT thermocouple install:
2 - 12mm wrenches
11/32 drill bit
1/8" npt tap
cordless drill (with low speed and variable clutch so you don't snap the tap!!)
ECT sending unit install:
14mm ratcheting wrench
17mm ratcheting wrench
teflon tape
The EGT was the more difficult of the two to install simply because I couldn't find my center punch ans drilling on a curved surface is a pita! Once I had it drilled there isn't enough room to get the "T" handle for the tap in there so I had to use the drill on low speed and very little clutch. Every 1/8- - 1/4 turn I'd have to back the drill out and increase the clutch a little. was scared I would break the tap off in the exhaust pipe Other than that, it was quite easy to install. The thermocouple wire was long enough to make it all the was into the cab and splice into the gauge harness. I routed both the TC wire and sending unit wire though the factory loom / wire bundles to keep everything clean looking. At the ECT sender I used a little black tape (scotch 33) to make the wires look a little more... "stock".
ID:	113329   Click image for larger version
Name:	EGT Completed.jpg
ID:	113337   Click image for larger version
Name:	Coolant temp sending unit.jpg
ID:	113345   Click image for larger version
ID:	113353   Click image for larger version
Name:	Tools needed for EGT install.jpg
Under the hood
studs to come
In the cab
mrc228 is offline
post #3 of 10 Old 05-18-2013, 05:41 PM
You didn't want to read eot \ ect threw the obd2 port?
Ryan
2003 2wd 6.0 egr gone, blue spring, extremeX
305/50/20 nitto 420s (lowered in the rear)
205/100 bw66
Boost got you loose
13.4 with a 1.9 60ft spinning anit winning
YOUR CUMMINS MIGHT BE FAST BUT YOUR GIRLFRIEND LIKES MY SLOW POWERSTROKE
my youtube channel mostly 6.0 videos
risco is offline
post #4 of 10 Old 05-18-2013, 06:08 PM
Powerstroke Techie
Lilpooh's Avatar
Feedback Score: 3 reviews
Using the down pipe for EGT reading will give you a low temp reading, as much as 400* less. The idea location will be the driver side exhaust manifold.
http://www.dieselmanor.com/diy/ford6...ugeinstall.asp
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #5 of 10 Old 05-18-2013, 09:14 PM Thread Starter
mrc228's Avatar
I really wasn't wanting to spend another $300-400 or more on something I thought I could accomplish for $200ish.
The three gauges, senders, thermocouple, and pillar pod were $227.
Right now I just don't have the money for much else. (Newly engaged and paying off a ring!!)
Also I wanted a clean install inside the truck. It needs to look like it belongs there. I haven't seen much that will make things like the edge look right and I can't afford a lot of custom work. Maybe I'm just not looking in the right place??
I'm definitly going to relocate the ect sending unit after checking it against the SCT tuner data logger as mentioned in my other post. I'm still assuming that I can get the eot from the top of the oil filter cap. It looks like the factory oil sender is right at the bottom of the oil filter so I'd assume the temps will be very close.
Under the hood
studs to come
In the cab
mrc228 is offline
post #6 of 10 Old 05-18-2013, 09:34 PM Thread Starter
mrc228's Avatar
I thought that you'd want to know what's going through the turbo? Why is it more important to know the temp pre-turbo than post-turbo?
Under the hood
studs to come
In the cab
mrc228 is offline
post #7 of 10 Old 05-23-2013, 07:34 PM Thread Starter
mrc228's Avatar
To update this, I've just got the dashboss for all critical monitoring of onboard sensors. The thing is amazing... I'm getting rid of the ect and eot and will be installing a second thermocouple pre-turbo in the manifold. I know I could simply move the thermocouple but after reading all of the pro's and con's for both sides of the argument I figured why not just look at both since I already have the pillar gauge pod. The last pod will hold a fuel pressure gauge eventually.
Sent from AutoGuide.com App
Under the hood
studs to come
In the cab
mrc228 is offline
post #8 of 10 Old 05-27-2013, 10:04 AM
If your gonna add another egt gauge I would put both in each manifold. It allows you to see any problem before they could cause a serous problem
Ryan
205/100 bw66
Boost got you loose
risco is offline
post #9 of 10 Old 05-29-2013, 09:24 PM Thread Starter
mrc228's Avatar
I decided against another egt. I've got fuel and oil pressure on the way. I may put another thermocouple back in the post turbo location one day just for more piece of mind on shutdown. If so I'm not adding another gauge inside e cab. I'll just use one of he up fitter switches and a relay so I can go back and forth when I want.
Under the hood
studs to come
In the cab
mrc228 is offline
post #10 of 10 Old 05-30-2013, 12:17 AM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
Feedback Score: 10 reviews
You can monitor both manifolds and the downpipe with the dashboss and your pyrometer gauge. That's what I do. I have both manifolds hooked to the dashboss and the analog is post turbo.
l BRYAN l
COMPIGNTECH .COM
Look us up on Facebook
COMPRESSION IGNITION TECHNOLOGIES
l 2005 l Ford F250 l FTX l
[A Few Odds-N-Ends]
Tuscany is offline
