My next things to do. - Ford Powerstroke Diesel Forum
post #1 of 2 Old 05-15-2013, 10:57 PM Thread Starter
Hey guys i just bought a 2006 F350 with 61k miles. just want you folks opinion. thx
-Sinister Diesel External Oil Filter System with Coolant Filter
or
-AMSOIL BMK-21 Oil filter Bypass/IPR High Flow Coolant Filter Ford 6.0 w/Coolant Manifold
-IPR GEN2 EGR Delete Kit, Ford OEM Oil Cooler & Gaskets
-SCT SF3 Power Flash Ford Programmer
-Insight CTS
-Blue Spring" Upgrade Kit
what do you folks think? thx guys
darren808 is offline
post #2 of 2 Old 05-16-2013, 01:29 AM
kcoyner's Avatar
Quoted: 74 Post(s)
1st thing: Be sure to have a way to monitor the systems on your truck.
Coolant filter is a good idea. Be sure the coolant has been changed to CAT ELC.
BPD bypass using the Amsoil filter.
SCT is great to have
At some point you are probably going to need an oil cooler and new or delete EGR. I recommend saving up for a BPD oil cooler. This may also be the time to do APR studs and replace OEM head gaskets.
k
2005 F-350 Lariat DRW, Asheville Engines Performance 20 Long Block with ARP studs and a Stage 2 Cam. EGR Delete. SCT tuner. Salvaged Banks High Ram Intake Elbow, Ram Air Filter and IC. Amsoil lubricants, Sinister Coolant Filter, Edge Insight CTS, SP Performance Rotors and Hawk Tow Pads, Motorcraft fuel and transmission filters, Mishimoto radiator, thermostat and silicone hoses. BulletProofDiesel water pump and Heavy Duty Oil Cooler. Marty's Diesel Regulated Return
kcoyner is online now
