Stage1 compair to Powermax - Ford Powerstroke Diesel Forum
post #1 of 19 Old 05-15-2013, 10:15 PM Thread Starter
madpowerstroke's Avatar
There has been people asking what is the difference between the stage 1 and Powermax, some have said the Powermax is just as good, others have stated that the stage 1 is better. I have said that the stage 1 flows more air, but I thought I would just show you the difference between the two. I took video of the two side by side and you know what they say a picture(video) is worth a thousand words. I described both and the differences, I also put air to both same pressure, and you can decide for yourself. Now the stage 1 comes standard with the billet wheel, and the powermax was shown with it's standard wheel. The billet wheel in the stage 1 is a drop in for the powermax., the stage 1 has a 13 blade turbine wheel which makes spool faster and throttle response better than the powermax even with same billet wheel. I didn't do anything special to make the stage 1 out shine, same air pressure. Thanks and enjoy
https://www.youtube.com/watch?v=rSYZ...e_gdata_player
https://www.youtube.com/watch?v=X_9z...e_gdata_player
2004 F250 Ext.cab fabtech 5.5" lift,and traction bars 35" on 18".2005-2007 grill and LED headlights,58v FICM, Warren dual HPOP system, fuel reg. return system, areo 1000a fuel pump, dual fuel filters, ARP studded heads, CCV reroute, EGR delete, 225/75 Warren injectors, water/meth injection (cooling mist),SCT tuner with customs, banks intercooler. MTW stage 4 turbo, built trans by Andy Warren, 4:10 Detroit lockers.
madpowerstroke is offline
post #2 of 19 Old 05-16-2013, 12:18 AM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
Feedback Score: 10 reviews
Man I LOVE the howl that the new billet wheel makes.
Btw I love the rifle sitting in the background!!
l BRYAN l
COMPIGNTECH .COM
Look us up on Facebook
COMPRESSION IGNITION TECHNOLOGIES
l 2005 l Ford F250 l FTX l
[A Few Odds-N-Ends]
Tuscany is offline
post #3 of 19 Old 05-16-2013, 03:04 AM
the chad's Avatar
Good work Adrian
Chad
07 F250
4'' MBRP to 7'' FTE Miter
ELC w/ Sinister Coolant filter
ARP's with OEM
Edge CS and Trans, Boost, FP on the pillar
Voltmeter in dash
Banjo's
Looney
Cal-Tracs
20x10 Monsters wrapped in 305 420s
RCD Egr Delete
Warren 190/75
Dozers RR
MTW Stage 2
557 hp/1206 ft/lbs
Big thanks to JJ @ Dozers And Adrian at MTW
the chad is offline
post #4 of 19 Old 05-16-2013, 04:16 AM
N.S.D.Q.
HeavyAssault's Avatar
Quoted: 97 Post(s)
Feedback Score: 3 reviews
LMAO....it sounds different due to the difference in compressor blade design. PLEASE explain how that means it flows more. After adding the single plane to my Pmax I have the same sound from the compressor side.
Officially The Biggest Midget In The Game
(In support of Zmann's request)
HeavyAssault is offline
post #5 of 19 Old 05-16-2013, 06:12 AM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
He was comparing a factory built powermax to his stage 1. Obviously the SAME billet wheel will flow the same BUT the powermax will not spool as fast or as hard as the stage 1 due to the fact it has a 10 blade turbine and no turbine housing tweaks.
l BRYAN l
COMPIGNTECH .COM
[A Few Odds-N-Ends]
Tuscany is offline
post #6 of 19 Old 05-16-2013, 06:18 AM
RIP Cam!
Rattlesnake18's Avatar
Quoted: 828 Post(s)
Feedback Score: 6 reviews
Good stuff Adrian!!!
2004 F250 CC Lariat 4x4
BPD FICM, BPD billet water pump, BPD VK688 oil cooler kit, S&B CAI, MTW stage 2, TSD tunes, Auto Meter gauges, Edge CTS, Sinister coolant filter, Blue spring, 6.4 banjo bolts, Straight piped w/ 6" single mitre stack, Pro Comp leveling kit, 05-07 HD headlights, Xenon-Vision 5k HIDs, Fumoto block drain valves, ELC, High idle mod
Originally Posted by djmaguire View Post
I'm guessing that you didn't lose nearly as much as it appeared. Spills are like that. The last beer that I spilled was like a million ounces.
Rattlesnake18 is offline
post #7 of 19 Old 05-16-2013, 07:03 AM
turbotibbo's Avatar
Nice thread !
2006 ford f350 xlt cclb
blue spring mod
6.4 banjo bolts
gogo direct cluth solenoid
Insight cts with pyro
str8 pipe , fuel pressure gauge
air raid cold air
zoodad mod
high idle mod
sinister coolant filter kit ec-1 rated
58 volt ficm
powermax turbo , sinister y pipe
egr delete
sct x3 with running looney wild , spd early lock up
arp studs , updated stc fitting ,stand pipes,
dummy plugs , new oem injectors
turbotibbo is offline
post #8 of 19 Old 05-16-2013, 08:26 AM
how about putting air pressure to the hot side. after all that is what actually spools the turbo. can you make a contraption to show that?
03 F350
Supercab short box
TS 5015
Studded, deleted, 155/30's
Grand rock power flow exhaust.
leveled on 35x12.5x20's
leece neville 230 amp alt.
Onefaststang is offline
post #9 of 19 Old 05-16-2013, 08:56 AM
Motor Head.
robertc68's Avatar
Quoted: 39 Post(s)
Subscribed.
04 350 DRW CC LB,4:10,245/75/17,tires 4X4..Coolant filter. CTS.Stage II AFE.EGR Delete,Zoodad ,regulated return, ,Arp,OemHG,AD150,WPE ported int,58FICM,190/30 Injec,05 coil conversion.WPE/KC 1.5 turbo,2011 rear leafs,13 tailgate,flight fab trac bars.2014 Power/folding/Extend mirrors.
robertc68 is offline
post #10 of 19 Old 05-16-2013, 11:42 AM Thread Starter
LMAO... you don't read to well, I stated that both turbos are in stock form, also the older cast wheel version also did the same. You don't seem to understand is that the design of the wheel makes a huge difference on spool and flow, also the turbine wheel blade count also has a big difference. The turbine is what makes the stage 1 better than the powermax, spool, lag, and throttle response. I have said it before can a powermax flow better a high rpm with same compressor wheel? yes at what rpm about 6300-7000, where a diesel won't run, same with the dual wheel design for the compressor to get the same flow as the single design it would have to get into higher rpm.
Yes I'm working on something now on, trying to get a leaf blower to act as drive pressure to act as the exhaust, the air won't be heated but it will give a base line if used the same on different turbos. I will have a hard time to get things exact due to need a oil supply to keep bearings in a journal to stay centered.
