E.G.R. blockoff? - Ford Powerstroke Diesel Forum
post #1 of 29 Old 03-03-2008, 05:06 PM Thread Starter
screech's Avatar
E.G.R. blockoff?
This post is for a friend, 04 6.0 banks 6gun, multiple other mods. Whe he gets on it on position 6, runs stong then goes into a limp mode, the coolant overflow tank belches coolant out. Is this due to the e.g.r. cooler, if so where can you find a blockoff plate? Are there any other fixes? Thanks
96 350 Reg.cab 7.3 5sp. 4x4
3.5 to 4in dp, 4in strait pipe
4in Superlift w/ Airlift airbags on 315/75/16 Procomp X-Allterain W16x10Procomp wheels
Ba### Technicooler(the bad word)
Boost & E.G.T. Guages
Superchips programer(for now)
fpr mod
d.i.y. intake
South Bend clutch
79 150 4x4 (my wheelin truck)
420ci M motor,c6
4in lift, 35x12.5x15 Mud Terains
was old driver too much $$$--6-9mpg of premium(11.5to1)
screech is offline
post #2 of 29 Old 03-03-2008, 05:09 PM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 19 Post(s)
Elite diesel sells the plate. When mine went, the headgaskets went also. I had arp head studs installed and the EGR blockoff. Just so he knows, with the plate in place, it will set an EGR code in the 6 Gun but doesn't effect the performance.
dhanna6powerstroke is offline
post #3 of 29 Old 03-03-2008, 05:09 PM
Slacker
Evil Eye's Avatar
Quoted: 190 Post(s)
Feedback Score: 4 reviews
Yes, this is the exhaust flash boiling the coolant in the EGR cooler causing your degas bottle to puke. Blocking it off will eliminate this problem, so long as your head gaskets are intact and your EGR cooler isn't already ruptured.
Shawn Carlson
Proud Navy Vet
2005 F250, CCSB, 6.0 PSD, FX4 (The Sweet Unit is white)
2008 F350, CCLB, 6.4 PSD (Brad-the wife's truck is black)
Engine Mods:
Fluidampr
CCV Reroute (Reinstated)
4" MBRP Exhaust
MTW Stage 1 Turbo
Bulletproof 53V FICM
BulletProof EGR Cooler
BulletProof Water Pump
Riff Raff Intercooler Boots
Gogo Diesel Direct Drive Solenoid
BulletProof All-Aluminum Radiator
BulletProof All-Aluminum Intercooler
BulletProof Oil Cooler System w/ Bypass Filter
SCT w/ Custom Tunes (TSD, DJ's, Innovative, Gearhead, QuickTricks)
Exterior Mods:
Bilstein 5100 Shocks
Icon Adjustable Trac Bar
Firestone RideRite Air Bags
BDS Dual Steering Stabilizer
Aluminum Finned Differential Cover
Reese 16k Manual Slider 5th Wheel Hitch
Icon 2.5" Leveling Kit w/ F-350 rear blocks
20" BMF Novakanes wrapped in 33" Nitto Terra Grapplers
Evil Eye is offline
post #4 of 29 Old 03-03-2008, 05:12 PM
Mod Newbie
Quoted: 19 Post(s)
Does it start puking out as soon as he gets on it turned to level 6? If so, the headgaskets are probably gone also. I had to run mine real hard for quite a while before it would start puking. Now I run mine on the SL level with no problems.
post #5 of 29 Old 03-03-2008, 05:41 PM Thread Starter
screech's Avatar
Thanks, I think it happens soon after running it hard. Like a hard accell thru all 6 gears. Is it worth doing the cooler blockoff to see? I also think it may need gaskets and studs, but wanted to talk to some of you. Thanks again.
fpr mod
d.i.y. intake
South Bend clutch
420ci M motor,c6
screech is offline
post #6 of 29 Old 03-03-2008, 05:46 PM
Mod Newbie
Quoted: 19 Post(s)
Definetely worth doing the block off plate. You can buy it for $15. If I were him, I would take the 6 Gun out and take it to a dealership that is aftermarket upgrade friendly and have it checked out. If they determine the headgaskets are blown and will cover it under warranty, you might be able to get them to install the studs and block off plate. That is what I did, but I use to work at the dealership I took mine to + I was good friends with the diesel tech. You can check on ebay and find the studs pretty cheap sometimes. I got mine for $450 shipped to me from Texas.
post #7 of 29 Old 03-03-2008, 05:58 PM
the appropriate tests need to be done to it to to determine if its one...or both...
generally speaking EGR coolers flash boil after a long hard run of 10 seconds or more...or while pulling up a grade...
EGR cooler failures generally blow a lot of white smoke (a LOT)
headgasket failures generally blow no white smoke and overheat and purge when boost pressure overcomes the clamping force of the streched headbolts.....this could be 5 psi or it could be 30 psi...and that sounds to me like the problem here.....
Plugged oil coolers can also cause flash boiling and purging....but never an overheat unless coolant is low...
mschn99 is offline
post #8 of 29 Old 03-03-2008, 06:15 PM
Mod Newbie
Quoted: 19 Post(s)
Mine was blowing so much smoke you couldn't see behind you. I blew the cooler and the headgaskets on both sides. Both heads had to be replaced along with 3 injectors and the turbo. It was blowing coolant and oil out the exhaust.
post #9 of 29 Old 03-03-2008, 06:54 PM
!!!PainTrain!!!'s Avatar
Ouch, sounds like you were luck it was covered.
Performance: SCT Xcal-Innovative Diesel, 4" Turbo Back Exhaust no muffler and kitty missing, Spearco IC, ID Power Elbow, AFe Stg. II Intake, 03 Turbo.
Exhaust Clip:
Looks: Westin Black Powder Coated Bull Bar, Recon Smoked Cab, Mirror Lights, and 3rd Brake Light, 4" Superlift kit, 35" ProComp Extreme A/T's, 18x10 Diamo Black & Chrome Rims.
!!!PainTrain!!! is offline
post #10 of 29 Old 03-03-2008, 07:02 PM
Mod Newbie
Quoted: 19 Post(s)
I had been trying to blow them since I bought the truck. I knew there was a problem with the factory bolts and I wanted to get the problem solved while it was under warranty. Glad I did too. No problems since repair, knock on wood!!
