turbo build date? - Ford Powerstroke Diesel Forum
post #1 of 3 Old 05-15-2013, 06:08 PM Thread Starter
turbo build date?
Hey everyone, I'm looking at getting a Wicked Wheel for my stock turbo but im having a tuff time figuring out what wheel is right for my turbo. I know this sound ridiculous but maybe I'm a dummy So my truck build date is 04/04 so I assume its an 04.5? question comes to...is there any ID on the turbo itself to go on and if so where would I find it??
I figure i could always look at the amount of fins on the turbine to figure it out but Id like to get the wheel before I rip the turbo out of the truck.
Thanks for bearing with me on this, all replies appreciated
BobD981 is offline
post #2 of 3 Old 05-15-2013, 08:12 PM
turbotibbo's Avatar
you can tell what turbo it is by the mounting bolt on the back of the turbo . if its a 03 turbo the pedistol will be different than an 04 . search it for pics
2006 ford f350 xlt cclb
blue spring mod
6.4 banjo bolts
gogo direct cluth solenoid
Insight cts with pyro
str8 pipe , fuel pressure gauge
air raid cold air
zoodad mod
high idle mod
sinister coolant filter kit ec-1 rated
58 volt ficm
powermax turbo , sinister y pipe
egr delete
sct x3 with running looney wild , spd early lock up
arp studs , updated stc fitting ,stand pipes,
dummy plugs , new oem injectors
turbotibbo is offline
post #3 of 3 Old 05-16-2013, 03:42 AM Thread Starter
Ok all three of my turbo bolts are vertical so that leads me to believe it has the newer style turbo. Thanks for the help!
BobD981 is offline
