EGT prove for sct livewire - Ford Powerstroke Diesel Forum
post #1 of 20 Old 05-15-2013, 09:12 AM Thread Starter
peixinho's Avatar
Quoted: 196 Post(s)
EGT probe for sct livewire
So I have seen almost two options for this...
One is to buy the kit... around $179 but...
I keep seeing the analog cable for sale in lots of place. On all the advertisements it says to use with egt probe??? but which one. I can't seem to find anyone that has done this route.
Could i just splice these two options together and it will work???
SCT 4021 Itsx or Livewire TS Analog Input Cable Connect EGT Boost or Wideband | eBay
EGT Probe Exhaust Gas Temperature Sensor | eBay
peixinho is offline
post #2 of 20 Old 05-15-2013, 09:19 AM Thread Starter
peixinho's Avatar
Quoted: 196 Post(s)
This seems to answer most people's questions but I am still a little confused
Originally Posted by portcity_gt View Post
I have had to help people with this the most by far.
The box your egt probe plugs into has a FireWire output, use the supplied cable from there into the inline box about a foot from where it plugs into your obd2 port. Select analog input #7 and equation "sct egt"
peixinho is offline
post #3 of 20 Old 05-15-2013, 05:18 PM Thread Starter
peixinho's Avatar
Quoted: 196 Post(s)
anybody have any insight on this?
peixinho is offline
post #4 of 20 Old 05-15-2013, 05:53 PM
licenced2burn's Avatar
What's your question exactly I'm a little confused on what your wanting to find out about it? I have a livewire laying around with a egt probe that I used before I bought my cts
Tony
2005 F250 crew cab lariat,
4" lift 325/65/18 tires, head studs, built trans, egr delete, powermax turbo, 58v ficm from swamps with mild flash, 4" straight pipe, sct with innovative xtreme street and race tune's, blue spring upgrade
Stage 3, 190/100 injectors, and full fuel system on the way.
licenced2burn is offline
post #5 of 20 Old 05-15-2013, 06:02 PM
sprksonu's Avatar
you can use this kit they say it is compatible PLX SM-EGT | Exhaust Gas Temperature EGT or call bullet proof diesel they might have some sct 9617 egt kit either will work
WRECKED EM DAMN NEAR KILLED EM!
2005 f250 ccsb 4x4 Studded, 03 turbo w/billet wheel, AFE stage2, 5"diamond eye, BPD egr cooler & "NEW" external oil cooler, BPD 48v FICM, BPD water pump, BPD aluminum radiator, 6.4 banjo's, blue spring, HFCM e-z drain, riff raff boots, gearhead srl tune , PHP FICM tune, sct livewire 5015, updated stc, updated stand pipes & dummy plugs, updated oil feed & drain, Zerex ELC coolant, Pro Comp 6" lift, 325/70/17 Toyo open country at
sprksonu is offline
post #6 of 20 Old 05-15-2013, 07:12 PM Thread Starter
peixinho's Avatar
Quoted: 196 Post(s)
SCT 4021 Itsx TSX for Android Smartphone Tablet Analog Cable Connector Wiring | eBay
This part is only $40 and it plugs into the livewire module, analog cable
The probe itself is only $50 dollars... that around $90 for the whole kit, unless I am missing something. IDP wants $180 for there kits?
I don't understand why everyone does not just go with the two options above. I was asking if I just splice the two wires together will it work?
Am I missing a piece of the puzzle?
peixinho is offline
post #7 of 20 Old 05-15-2013, 07:22 PM Thread Starter
peixinho's Avatar
Quoted: 196 Post(s)
So do I still need the analog wire to connect up to the livewire? or is this everything i need
peixinho is offline
post #8 of 20 Old 05-15-2013, 07:41 PM
sprksonu's Avatar
im not sure i would contact them and ask.
sprksonu is offline
post #9 of 20 Old 05-16-2013, 02:16 PM Thread Starter
peixinho's Avatar
Quoted: 196 Post(s)
i guess what I am confused about is the sensor mudule (red box in the link provided)... i put and egt guage on my 7.3 and I did not need that?
My idea was just the probe, staight into the analog cable, which plugs into the sct livewire... what is the reason or necessity for the module?
peixinho is offline
post #10 of 20 Old 05-16-2013, 07:18 PM
Powerstroke Techie
Lilpooh's Avatar
Feedback Score: 3 reviews
The box is a volt amplifier (0-5v amp). EGT probes (thermocouples) put out millivolts, you need the box to amp up the volts, because the Livewire reads the volts and converts to temp.
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
