injector time - Ford Powerstroke Diesel Forum
post #1 of 42 Old 05-14-2013, 08:38 AM Thread Starter
injector time
hey guys i need some opinions. my truck has recently begun to have stiction at about 55-60 mph i have changed the oil with rotella 15w-40 and added two bottles of rev x. no change. so while i have the funds avaliable i was going to go ahead and send my injectors to warren to be rebuilt. my delimma is i tow a decent amount about 13k-16k. what would be a good size injector for this ? i was leaning towards a 155/50 or a 175/30. i do have future plans for a mtw hybrid. will my stock fuel system be able to supply enough fuel to either of these injector options?
any help./advice would be appreciated
thanks.
truck: 06 f350 reg cab 4x4 xl mods-arps, oem head gaskets, bluespring, 6.4 banjo bolts, rcd egr delete, newer hpop, 4 inch turbo back strait pipe, sct livewire tuned by matt at gearheads
kypowerstroke21 is offline
post #2 of 42 Old 05-14-2013, 08:57 AM
JGman141's Avatar
I'd go with 175/stock since you tow kinda heavy. You stock fuel system should be able to keep up if you have a healthy pump.
2004 6.0 ccsb Warren 430/150 hybrids, Warren Comp Trans, Warren Dual Hpop, Billet S475 w/race cover, Marty's A1000 Fuel System, Colt stage 2 and all the other supporting stuff
JGman141 is offline
post #3 of 42 Old 05-14-2013, 09:56 AM
Powerstroke Techie
Lilpooh's Avatar
Feedback Score: 3 reviews
Please explain your "stiction" issue at 55-60mph.
Have you tested and confirmed possible other issues, like FICMv, Fuel psi, tested injectors, CCTest, power balance, fuel aeration, correct fuel and oil filters.
You may have another issue that needs to be corrected before throwing injectors at it.
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #4 of 42 Old 05-14-2013, 10:15 AM Thread Starter
I've heard that the 175/stock will raise cylinder pressure to an unsafe level?
post #5 of 42 Old 05-14-2013, 11:01 AM
Not true all in the tune for cylinder pressures bud
Late 04 f350 lariat.
bpd
marty's regulated return
205/75 injects from holder's
WPE stage 3 ported intake
64.5 borg warner fmw ,compounds in the works now! Comp turbo set up
Warren comp trans
all the typical mods
Big thanks to Dale! The man is a true professional
04cr450 is offline
post #6 of 42 Old 05-14-2013, 11:28 AM Thread Starter
Ohh ok well I stand corrected. Would the 175/stock give me a decent boost in power?
post #7 of 42 Old 05-14-2013, 11:30 AM
Yes. But nowhere near if you put say 30% nozzles on to match it...
bpd
Warren comp trans
04cr450 is offline
post #8 of 42 Old 05-14-2013, 11:31 AM
Before my new injectors I had 155/30's with stock turbo and it ran like a dream. EGTS were always low- that being said though my truck has never towed anything so I cant comment on towing.
bpd
Warren comp trans
04cr450 is offline
post #9 of 42 Old 05-14-2013, 12:10 PM Thread Starter
Did you have any fuel pulled out of your Tunes ?
post #10 of 42 Old 05-14-2013, 12:25 PM Thread Starter
