Turbo Y-pipe - Ford Powerstroke Diesel Forum
post #1 of 13 Old 05-13-2013, 08:33 PM Thread Starter
Turbo Y-pipe
I believe I have the symptoms or a cracked Y-pipe. Diesel smell in cab, turbo really lags when it's warm outside etc.
I'm doing a IPR EGR delete with up-pipe soon with some other upgraded stuff and if I find the Y-pipe is cracked ill obviously be replacing.
Question is, should I go with OEM or aftermarket? I see that Sinister has a Y-pipe setup, but it's also like $400.
Any opinions are appreciated.
Sent from AutoGuide.com App
Alpha Male is offline
post #2 of 13 Old 05-14-2013, 08:16 AM
Term3's Avatar
You could take it to a good muffler shop and have them weld in new flex joints. It would be a lot cheaper.
SCT, no studs...yet, Dual OEM intake air filter housings, Banks intercooler & intake elbow, Banks exhaust system, Windrunner ported intake manifold, Bullet Proof Diesel remote oil cooler & thermostat, AirDog2 (plus a couple spares), Power steering filter (Amsoil dual-bypass), MagTec deep ATF pan, Electric oil pre-lub pump, Dakota Digital gauges.
Term3 is offline
post #3 of 13 Old 05-14-2013, 09:43 AM
strokin6L's Avatar
Quoted: 3 Post(s)
Store
2004 F-350 SC 4x4, XLT, 4" dual Magnaflow, AFE intake, No Limit piping, spearco intercooler, water injection, ARP studs, hypemax o-ringed heads, SCT tuned by Innovative Diesel, tuned FICM, Hellman's sump, FASS, Fuelab, regulated return, 190/75 injectors, KC/MTW 68 w/.72ar, suncoast trans w/billet input, edge insight CS with dakota digital gauges, amsoil by-pass, BD exhaust manifolds
strokin6L is offline
post #4 of 13 Old 05-14-2013, 10:44 AM Thread Starter
Wouldn't something that was just a solid pipe be better than something with flex joints?
post #5 of 13 Old 05-14-2013, 10:46 AM
william_ace's Avatar
Quoted: 2 Post(s)
I would definitly go with that one. Strokers unlimited also sells them, but they are slow to deliver.
2004 CCLB 6.0 6 speed 4x4
ARP Studs with OEM Gaskets
Barder Stage 3 / Holders 205/100s
Southbend Dual Disk Clutch
Odawg fully ported and deleted intake manifold
4" MBRP Turbo Back
Windrunner regulated Return with custom Y-pipes
Cat EC-1 with coolant filter
Flyin Diesel Sump w/ fuel lab 4201
william_ace is offline
post #6 of 13 Old 05-14-2013, 10:48 AM
Quoted: 2 Post(s)
You could try that, but you wont like putting it on. The flex joints allow for a little movement when the engine moves, and for a MUCH easier install.
4" MBRP Turbo Back
post #7 of 13 Old 05-14-2013, 11:00 AM Thread Starter
The price isn't too bad either. And that pipe will fit with the IPR up pipe right?
post #8 of 13 Old 05-14-2013, 11:15 AM
strokin6L's Avatar
Quoted: 3 Post(s)
Personally I'd go with a flex joint y pipe over the one piece no flex joint y pipe any day
post #9 of 13 Old 05-14-2013, 11:29 AM
04cr450's Avatar
Strokers does wonderful work, my up-pipe turned out great... Problem was customer service as mentioned above.
Late 04 f350 lariat.
bpd
marty's regulated return
205/75 injects from holder's
WPE stage 3 ported intake
64.5 borg warner fmw ,compounds in the works now! Comp turbo set up
Warren comp trans
all the typical mods
Big thanks to Dale! The man is a true professional
04cr450 is offline
post #10 of 13 Old 05-14-2013, 12:06 PM
Term3's Avatar
I phoned them a while back asking about any possible issues with stress due to heat cycling and/or vibrations and they stated that they have never had a reported failure so far. Still has me wondering about long term use though.
Term3 is offline
