Head stud install quote? - Ford Powerstroke Diesel Forum
post #1 of 10 Old 03-01-2008, 08:02 PM Thread Starter
HD Jimbo's Avatar
What would a reasonable ARP installation run on a 2005 DRW?
HD Jimbo is offline
post #2 of 10 Old 03-01-2008, 08:13 PM
The Fat Mod
Logan's Avatar
Well, depends on if you can get someone to do them under warranty or not. If you can it will be $100 plus the cost of the studs.
Logan is offline
post #3 of 10 Old 03-01-2008, 08:15 PM Thread Starter
HD Jimbo's Avatar
Does FORD cover it if you have a tuner/chip/etc?
If they don't let's say it would have to be done OUT-OF-WARRANTY, I've heard the dealership can run up to $2500 or so, and what would an aftermarket performance shop run?
HD Jimbo is offline
post #4 of 10 Old 03-02-2008, 05:11 AM
MOMBENZ's Avatar
Hi,
We do headstuds in Ocala, Florida. We also know of shops around the country that may be in your area. Let me know.
Thanks,
Vivian
MOMBENZ is offline
post #5 of 10 Old 03-02-2008, 05:34 AM
DKR
<--Pro Cooler Racer
DKR's Avatar
I've heard of quotes ranging from $1500-$2500 plus studs. But that is just installing the studs. If you have to do it out of warranty and your heads are out of spec, now you're talking even more big bucks. So I always say, if your within warranty, reset back to stock and try a dealer. It can't hurt to try.
Oh, and Logan, I lucked out, no $100 deduct. for me, I was less then 36,000 miles.
Eric
2007 F250 6.0l King Ranch CC LB
Sponsored by Innovative Diesel Performance
SCT XCal2 w/ Custom Files & FICM tuning
DashDAQ Series II; ARP Headstuds; AFE Stage 2 XP Intake w/ Proguard 7
Industrial Injection 190cc injectors; FASS 150/180; ITP Regulated Return
'03 Turbo Swap; Zex N2O Dry Shot; CFM Smallmouth Intake Elbow
Zoodad w/ Predator Screen; MBRP 4" Cool Duals Straight Piped
EGR Delete w/ full manifold; Coolant Bypass Filter; Train Horns
Eclipse AVN62D; High Idle Mod; BFG ATs 285-65/20s
Truck- 12.51sec @ 108mph @ ~7700lbs (1/4 mi)
Cooler- 39.93sec @ 12.12mph @ ~180lbs (1/8 mi)
Email:
DKR is offline
post #6 of 10 Old 03-02-2008, 08:26 AM Thread Starter
HD Jimbo's Avatar
Ok, I'm just trying to get an idea because I'm looking at a 2005 DRW. If you all have had success after running a chip/tuner and getting the head studs under warranty, I think I'll risk it and set it back to stock if it happens...
HD Jimbo is offline
post #7 of 10 Old 03-02-2008, 08:29 AM
The Fat Mod
Logan's Avatar
It is not as much of getting lucky...it is knowing the right people.
Logan is offline
post #8 of 10 Old 03-02-2008, 08:30 AM
99SMOKR's Avatar
jim, those arent horribly bad to do, just get Rich or Jesse to do it. Way cheaper
if you want you can also pay those guys in beer too, hahaha
1999 Powerstroke Diesel
K&N Intake, 4" downpipe to 7" Stacks, Edge Juice chip(with Attitude display), Bully Dog shift kit, X-wheel
352 HP
678 TQ (w/stacked EVO)
BUILT not BOUGHT
99SMOKR is offline
post #9 of 10 Old 03-02-2008, 08:34 AM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 20 Post(s)
A lot of times you can tak the chip, tuner out of truck and take it in. However if the dealer wants to be difficult and a rep comes down, they can tell a chip or tuner has been installed just by looking at the top of the pistons. The burn pattern on the piston is a perfect 6 sided star if the chip has been installed. I got lucky when I had mine done because I used to work at the dealership I took it to and was real good friends with the diesel tech. Cost me $100 ded. + $450 for the studs.
dhanna6powerstroke is offline
post #10 of 10 Old 03-02-2008, 08:47 AM Thread Starter
HD Jimbo's Avatar
That's right... and we could use the crane over at Peterbilt!
HD Jimbo is offline
