Weird shifting issue - Ford Powerstroke Diesel Forum
post #1 of 3 Old 05-13-2013, 06:10 AM Thread Starter
This all started a couple weeks ago at our track/dyno day. I ran down the track 4 times and all was great. On my 5th run I went to leave the lights (4x4 boosted launch) and when I took off the truck was down on power. Comes time for the first shift, it hangs at 4K rpm for a few seconds and the bam slams into gear the second shift was the same and I let off and coasted to the end. I thought maybe it was a fluke and tried running again with same results. Went off to the side, pulled trans dipstick, fluid smells and looks good. I leave the track go out driving around in 2wd, trans shifts great even at wot. Have been driving around the last 2 weeks with the looney and it shifted great. Tried to do a 4x4 boosted launch yesterday just for the heck of it and same thing that happened at the track. It took off like it was bogged down, got to the first shift and just hung, then bam it will shift. I put it back in 2wd and it started doing the same thing in 2wd now! Pulled over took the looney out, put srl in and bam full power, shifts great. This leads me to believe it is in my looney tune, but why did it just come about one day out of the blue? Sorry for the book, but any ideas? Tranny issue, tune issue or something else?
2003 F-250 ECSB 4x4
4" MBRP turbo back
SCT
S&B cai
435 rwhp / 767 rwtq
13.94 @ 97 (with a terrible 60')
Jesse S is offline
post #2 of 3 Old 05-13-2013, 04:01 PM
turbotibbo's Avatar
your not the only one to have shifting problems running
the looney . but if the slr dont do it and the looney does , leads me to belive its the looney . thats just my opnion tho . good luck and keep this thread updated please ,
2006 ford f350 xlt cclb
blue spring mod
6.4 banjo bolts
gogo direct cluth solenoid
Insight cts with pyro
str8 pipe , fuel pressure gauge
air raid cold air
zoodad mod
high idle mod
sinister coolant filter kit ec-1 rated
58 volt ficm
powermax turbo , sinister y pipe
egr delete
sct x3 with running looney wild , spd early lock up
arp studs , updated stc fitting ,stand pipes,
dummy plugs , new oem injectors
turbotibbo is offline
post #3 of 3 Old 05-14-2013, 05:13 AM Thread Starter
Small update. I drove the truck fairly hard yesterday with the srl loaded, even did a few 4x4 boosted launches. Not one issue and the trans acted great. Dropped the truck off at the shop today to have them change both trans filters and top off with fluid.
2003 F-250 ECSB 4x4
4" MBRP turbo back
SCT
S&B cai
435 rwhp / 767 rwtq
Jesse S is offline
