My build update - Ford Powerstroke Diesel Forum
post #1 of 11 Old 05-12-2013, 10:08 AM Thread Starter
My build update
Hey guys, just wanted to add my build progress, updates and pictures in the mix. Mods are in my signature, just about finished. Waiting on a ficm harness from tousley(I broke the clips off mine), flush the coolant system, and she's ready to run. Really excited to get this thing going- running srl tunes from matt setup for 175/75 injectors etc. Should be a good combination of everything.
Added a new 7" flow pro tip- it thought it looks pretty good.
And of course gotta get two of the best stickers out there
Late 04 f350 lariat.
bpd
marty's regulated return
205/75 injects from holder's
WPE stage 3 ported intake
64.5 borg warner fmw ,compounds in the works now! Comp turbo set up
Warren comp trans
all the typical mods
Big thanks to Dale! The man is a true professional
04cr450 is offline
post #2 of 11 Old 05-12-2013, 01:42 PM
5fifty's Avatar
Sounds like you got a good combo. It will be worth the wait. Good luck with it.
2005 F-550 4x4 22.5's
Kelderman Air Ride
Bulletproof Diesel Remote Oil Cooler W/F550 Cooler
Bulletproof Diesel Billet Water Pump
Bulletproof Diesel Radiator
Dieselsite Wicked Wheel, Dieselsite Coolant Filter Kit
Warren Diesel 155/30, Bluespring Mod, 6.4 Banjo,
Updated STC, Turbo Feed and Drain Tubes,
PMM EGR Delete
SCT Tuner, Edge Insight w/EGT, Fuel and Oil Pressure
Tuned By MATT @ Gearhead Automotive Performance
5fifty is offline
post #3 of 11 Old 05-12-2013, 05:16 PM
MrOneEyedBoh's Avatar
Quoted: 13 Post(s)
Feedback Score: 11 reviews
Beast bro
MrOneEyedBoh is offline
post #4 of 11 Old 05-13-2013, 02:48 AM
If Mitch's engine compartment was that clean it would have taken at least a month off his build. haha
WLDHRSE is offline
post #5 of 11 Old 05-13-2013, 06:16 AM Thread Starter
Hahaha oh come on now cliff! Lol nothing like cleaning whirly birds out of injector cups
bpd
Warren comp trans
04cr450 is offline
post #6 of 11 Old 05-13-2013, 05:55 PM
Quoted: 5 Post(s)
Feedback Score: 3 reviews
Someone stuck a sticker of a bald guy to your back window. it's cool though man we must use the same haircut place LOL
2005 Harley F-250 CCSB
True Blue Metallic
Engine: ARPs, OEM oil cooler, Bed plate reseal, OEM HGs, Stand Pipes, Dummy Plugs, STC Fitting update, Bulletproof EGR, Rotella Ultra ELC, Sinister Coolant Filter, Machined stock heads, Blue spring
Exterior: Nitto Terra Grappler 295/60/20s on stock Harley 20s
Interior: Edge Insight CTS w/ EAS Fuel Pressure & EGT
Trans: PI Stallion, Billet input shaft, new clutches, 08 pan/filter
white59rt is offline
post #7 of 11 Old 05-13-2013, 06:36 PM
So is that thing running yet? I'm still not completely convinced you even have a truck...
Every time I've seen you you've been driving some damn Chebbie! haha
WLDHRSE is offline
post #8 of 11 Old 05-13-2013, 07:22 PM Thread Starter
Hahahaha well.... I just got done a couple hours ago venting to Dale about quality control on ford wiring harnesses.....I got the new ficm harness and guess what?? The ficm plugs were installed backwards, upside down, and not even close to the correct length to reach the ficm.. What a pile! Good news, Tousley pulled through and is overnighting me a new one.. Truck should be running wednsday. Thank goodness- been 5 weeks
bpd
Warren comp trans
04cr450 is offline
post #9 of 11 Old 05-13-2013, 07:24 PM Thread Starter
Ha Ha Ha I know, best haircut there is buddy!
bpd
Warren comp trans
04cr450 is offline
post #10 of 11 Old 05-13-2013, 08:41 PM
Quoted: 13 Post(s)
I wanna see it too haha
