Is an external oil filter necessary? - Ford Powerstroke Diesel Forum
post #1 of 17 Old 05-11-2013, 07:36 PM Thread Starter
njnick's Avatar
I was on Sinister Diesel's website looking to buy a coolant filtration system and saw an external oil filtration system. Does it just double filter the oil? For 400 bucks it seems like a lot just to add another filter. I know how crucial the oil is in operating the injectors but is it really worth it?
njnick is offline
post #2 of 17 Old 05-11-2013, 08:21 PM
Its nice but not necessary. Use a quality oil, 5-40 synthetic, a ford filter and change every 5k and you will be good to go
06 f350: 8" ICON 2.5 resi's, ouo ala's, pmf track bar, dual stabilizers, custom 5" exhaust, 37" BFG km2's, 4.30s, 08 tailgate w/step, 08 tail lights, coolant filter, BPB oil cooler w/p 58v ficm and radiator, ARPs, 175cc, MTW s1 billet, ported intake, egr delete, onboard air and gearhead tunes
All the above just to haul the 900hp street mustang
94slowbra is offline
post #3 of 17 Old 05-11-2013, 08:31 PM
ZMANN's Avatar
Quoted: 1455 Post(s)
while not necessary they filter to a finer Micron than your oil filter can
How?
they filter at a reduced volume since it takes the oil longer to go through the filter media
We Miss you Ronnie
ZMANN is online now
post #4 of 17 Old 05-11-2013, 08:33 PM
MrOneEyedBoh's Avatar
Quoted: 13 Post(s)
Feedback Score: 11 reviews
Its another preventative maintenence item. Some people show their oil Carr using a bypass and the oil doesn't look that bad. But that would be dependent on how clean your engine is inside. But it does help with filtering that soot or whatever out of the oil thus making our injectors much happier.
MrOneEyedBoh is online now
post #5 of 17 Old 05-11-2013, 08:43 PM
Sinister Diesel Sucks!!!
michaelaiman's Avatar
Quoted: 270 Post(s)
Amsoil advertises their bypass filter as filtering down to 2 microns, which as MrOneEyedBoh stated is low enough to filter out soot, in turn helping injector life. I built my bypass for about $100. If you're still on oem style oil filter housing it'll cost you bout $200. Most of your cost goes into the billet caps
03 F350 SD 6.0 PSD FX4 XLT CC LB SRW FOR SALE!!
To see why you should avoid Sinister Diesel, visit these threads:
michaelaiman is offline
post #6 of 17 Old 05-12-2013, 06:19 AM
Quoted: 270 Post(s)
Here's the thread I had started at one point
Building an oil bypass filter kit
post #7 of 17 Old 05-12-2013, 07:19 AM
jetjock15's Avatar
Quoted: 111 Post(s)
I lost an injector at 20k and dealer replaced under warranty. I added a bypass oil filter (mines the FS2500) to prevent and now I've gone another 20k with no issues. I like to think that it was part of the solution. If you read about how are injectors work, and how they fail - I think it's a wise investment.
King/Deavers/37s/AF 22x12s/4:56/F/R Detroits/Road Armors/Warn12k/155/30s, MTW S1Billet/GoGo Manifold/Banks IC/NADP Heavy Hauler Trans/ORU Hydro-Steer/PHP tow Tune/BPD HD oil cooler/Oil & Coolant bypass/AMP steps/TransferFlow tank-toolbox
jetjock15 is offline
post #8 of 17 Old 05-14-2013, 05:24 AM
Powerstroke Techie
Lilpooh's Avatar
Feedback Score: 3 reviews
Did you get a chance to install the threaded adapter for the Amsoil filter?
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #9 of 17 Old 05-14-2013, 06:33 AM
Quoted: 270 Post(s)
No sir, I have not. Waitin on the next oil change. Filter is on order though.
post #10 of 17 Old 05-14-2013, 06:35 AM
Quoted: 270 Post(s)
P.S. i went by your house yesterday.... Stalker style
