Injector Clips - Ford Powerstroke Diesel Forum
post #1 of 12 Old 05-11-2013, 07:26 PM Thread Starter
twoicebergs's Avatar
Quoted: 46 Post(s)
Injector Clips
A week ago I dyno'd my truck. I didn't use a dyno tune and the operator was having problems with how he was laying on the power to keep it in 5th. As well, even though it was a dual eddy current dyno, it was not loaded enough to let the truck build max torque, so it kept running out of RPM before the PW or boost were maxed out. To add insult to injury, it developed a miss on the drive into town. To make a long story shorter, the truck put out 790 lb-ft and 440hp, not bad for 3 second runs (I am not kidding) and a miss. He did over 15 runs and the temp never broke 1000*. So I drove it home somewhat disappointed, played with it for a few minutes and it was acting like it was running on 7 cylinders. So I put it in the garage and got ready to go to work.
So I was out of the country last week and this morning I played with the injector connections and hooked up the AE to see what was broke. Of course, I can't duplicate it and the truck is running strong. There is a slight vibration at 1200rpm, but it shows perfect on the power balance test. So when I deselected each injector, #8 sounded slightly different than the others. I pulled the harness off and on re-installing it, the plug was not latching correctly. My next step was to pull the clip and of course, it slipped off and fell under the intake manifold. I tried to get it back, but it just wasn't cooperating. I called the local dealer and he can't get any in till next week (need to buy 4@ $8 each). So I call up a recycler and he says he has a 6.0l in the yard and it may have them. So I go to pull another one to take with me and as it is just about in my hand, I hit a wire and it decided to join its buddy in the valley. 4 recyclers later and no clips...
So here is what I made out of some spare Stainless TIG rod. It works as good as the pretty ones from Ford. I will retrieve the originals when I do my oil cooler later this or next year, assuming they are still there. The rod is quite similar as far as strength and spring.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #2 of 12 Old 05-11-2013, 08:47 PM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 20 Post(s)
That sucks. You do know that you can just press on the closed end of the clip towards the open end and it will allow the plug to come loose from the injector connector?
dhanna6powerstroke is offline
post #3 of 12 Old 05-11-2013, 08:53 PM
Bump To Pass!!
toren302's Avatar
Quoted: 1656 Post(s)
This is the way I have always done them. Never even thought of pulling them out.
toren302 is offline
post #4 of 12 Old 05-11-2013, 09:11 PM Thread Starter
Quoted: 46 Post(s)
Yes, that is why the ends are angled, squeeze them and they pop out of the grove. The problem was for whatever reason it wasn't holding, hence the pull and almost re-seat. The second push was firm enough to almost push the injector plug back into the valve casing. I had to gently pull it back to the snap or I would have had to pull the cover to re-seat it. The second clip was just icing on the cake. I wasn't going to pull it off, and then I thought about "what if they have something close". In any case, the clips took about a minute to make. A lot less than the hour I drove to attempt to get replacements. Like I said, easy to make with the small TIG wire.
Frank
Working for Toys
post #5 of 12 Old 05-11-2013, 09:51 PM
onebadcoastie's Avatar
Quoted: 10 Post(s)
Did you just use needle nose to bend it?? Looks good!!
Shack
2016 F-350 CC Dually
2005 F250 CC FX4.SOLD
onebadcoastie is offline
post #6 of 12 Old 05-11-2013, 10:15 PM Thread Starter
Quoted: 46 Post(s)
One needle and one small square. The first one I made out of softer wire was pretty ugly. It was actually easier with the stainless being harder to bend.
Frank
Working for Toys
post #7 of 12 Old 05-12-2013, 11:20 AM
04cr450's Avatar
Ingenuity right there! I have never pulled the clips out either, weird they wouldn't clip back in..
Late 04 f350 lariat.
bpd
marty's regulated return
205/75 injects from holder's
WPE stage 3 ported intake
64.5 borg warner fmw ,compounds in the works now! Comp turbo set up
Warren comp trans
all the typical mods
Big thanks to Dale! The man is a true professional
04cr450 is offline
post #8 of 12 Old 05-12-2013, 11:25 AM
Quoted: 10 Post(s)
I've always pulled them. As a matter fact, I'm still confused at how else to get them out of there...lol
Shack
post #9 of 12 Old 05-12-2013, 03:52 PM Thread Starter
Quoted: 46 Post(s)
If you push on the closed end it forces the sides open as the lower bends push against the plastic housing, allowing for an easy separation. When you release it or pull it back to the grove, it is ready to relock into the grove on the inner connector. Sometimes only one side catches or they both partially catch and after a while it vibrates loose. That is probably what caused the miss. The problem was the truck was running so strong, having one cylinder dropping was pretty much unnoticeable, except for the lower than expected power on the dyno. The dyno problems further masked it.
Frank
Working for Toys
post #10 of 12 Old 05-12-2013, 04:10 PM
i completely agree on my truck with bigger injectors you can't really tell it is running on 7. the only way i new was when is was od at 45 and you give it gas it just vibrates and bucks other than that it runs fine just driving around of coarse
Ryan
2003 2wd 6.0 egr gone, blue spring, extremeX
305/50/20 nitto 420s (lowered in the rear)
205/100 bw66
Boost got you loose
13.4 with a 1.9 60ft spinning anit winning
YOUR CUMMINS MIGHT BE FAST BUT YOUR GIRLFRIEND LIKES MY SLOW POWERSTROKE
my youtube channel mostly 6.0 videos
risco is offline
