Turbo swap - Ford Powerstroke Diesel Forum
Old 02-28-2008, 05:57 PM
Illiana Chapter Director
Turbo swap
Just wondering what the advantages/disadvantages are for swapping an 03 turbo into newer trucks. Have seen where some guys are doing that. Also I was wondering why some 6.0 trucks seem to have a lot more whistle out of the exhaust than others. I have a silverline exhaust turbo back but does not have as much whistle as I would like. Didn't know if there was something I could do to make it louder or not. Appreciate any info.
Old 02-28-2008, 06:03 PM
DKR DKR is offline
<--Pro Cooler Racer
I just did the swap last Saturday.
So far, I have noticed a slightly quicker spool up, and much smoother spool. And running the same tunes (will be rewritten and track tested this weekend) I have already seen 5#s more boost. The 03 lets a larger volume of air in at the higher RPMs also. Before the swap, I was tuned at no more than 24#s max boost, I am at 29 now, and should see about 34ish when rewritten. I am also studded on my engine.
AND, I get the really cool, and LOUD, jet whistle now as I am straight piped turbo out..
The whistle comes from the exhaust vanes, 10 on an 03, 12 or 13 on an 04, and 15 on the 05s and up.
Hope that helps.
Old 02-28-2008, 06:06 PM
DKR DKR is offline
<--Pro Cooler Racer
Here is a link to a quick vid of my swap, before and after, with a comparision of the turbos. Enjoy!
07 to 03 Turbo Swap
Old 02-28-2008, 06:07 PM
Mines an 04 and I am getting about 36 PSI when the 6 gun is turned up. I had mine straight piped at one time and at higher rpm's it sounded like a big block gas motor. Couldn't handle that crap!!
Old 02-28-2008, 06:09 PM
DKR DKR is offline
<--Pro Cooler Racer
Higher boost doesn't always mean more power...my best times were run at a max of 24. That is one of the great things about custom tunes on a SCT. 36#s is pushing the threshold limits.
Eric at Innovative explained to me one night about higher boost vs lower, unfortunalty I cant recall enough of it right now to be thorough on explaining it.
Old 02-28-2008, 06:29 PM
DKR, does it seem to run better on the butt-o-meter? Do you recall the part # for the pedestal? How much was it?
Old 02-28-2008, 06:33 PM
I would be interested in knowing why thwy run better at lower vs. higher boost levels. When they run right, they were between 22-25 from the factory.
Old 02-28-2008, 06:36 PM
DKR DKR is offline
<--Pro Cooler Racer
Yes, by the "butt-o-meter" , it does seem to pull better and stronger. I will know for sure Saturday as I will be doing runs without the N2O for comparision.
As for part numbers and prices...
Pedestal LIST $226.79
Ford PN 3C3Z-6N639-BA
Hardware Kit LIST $8.53
Ford PN 3C3Z-9T514-AD
That is the list Ford prices, I have heard of them goin for anything from 140 something to list.
Old 02-28-2008, 06:38 PM
How did you come by your turbo? Meaning, what's the easiest way to get ahold of a 03 turbo?
DKR DKR is offline
<--Pro Cooler Racer
I will see if I can get Eric to chime in with the explaination when he gets a chance. IDP has been pretty busy recently.
I saw about 28 max when I was stock, so I was seeing less than stock after tuning, and that was on my Xtreme Street and my Xtreme Race files.
EDIT: I PMed Eric this thread.
