Edge Evolution DTC- HELP ME! - Ford Powerstroke Diesel Forum
post #1 of 13 Old 05-09-2013, 04:25 PM Thread Starter
Question Edge Evolution DTC- HELP ME!
Any way i have a 04 F-250 6.0
My truck runs like crap when the motor is cold and if i plug her in shes fine. I checked the FICM last year and the volts were good, and gave up on fixing it.
I just got the Edge Evolution chip and am getting some DTC codes. Have y"all seen any of these and what do i need to do?
Codes
Exhaucst gas recirculation sensorb circ lo
P0488: EGR throttle pos ctrl range/perf
P2290: Injector ctrl press too low
U0306: Software incornpatibity with FICM
Thanks y"all
NVRSFT is offline
post #2 of 13 Old 05-09-2013, 05:22 PM
Powerstroke Techie
Lilpooh's Avatar
Feedback Score: 3 reviews
Welcome to the org!!
First we need to know that mods are done to the truck. Those codes could be set from a EGR delete and the FICM code could be from a FICM reflash, but won't know until you give as much info on the truck as possible.
Also, is it a early build 04 or late build 04. The early 04's have the 03 motor in it, and it's common for the ICP sensor behind the turbo to leak or wire damage.
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #3 of 13 Old 05-09-2013, 06:06 PM Thread Starter
I have a bullydog cold air intake and 3" turbo back ext also that chip and that's it for now. And she is a 07/03 model
NVRSFT is offline
post #4 of 13 Old 05-09-2013, 06:33 PM
Powerstroke Techie
Lilpooh's Avatar
EGR codes could be a stuck EGR valve or bad valve, give it a cleaning and clear the codes.
http://www.forddoctorsdts.com/articl...icle-06-12.php
The P2290 can be caused from a faulty ICP sensor, which is common on the 03 motor. Look for oil leaking from sensor and look for damage to the wires and plug, if wires are damages or brittle, the ford dealer sells a wire harness kit to fix issue, if sensor has oil leaking from it, replace sensor also.
http://www.forddoctorsdts.com/articl...icle-10-06.php
The U0306 is harmless, it just means the FICM software doesn't match the PCM software. Maybe the past owner replaced FICM with a late 04 or 05-07 FICM, or was programmed with the wrong software. To correct this, you can have the dealer program the FICM software to match the PCM or contact PHP.
Lilpooh is offline
post #5 of 13 Old 05-09-2013, 07:33 PM Thread Starter
Thanks i'll work on her tomorrow after work and then post updates
NVRSFT is offline
post #6 of 13 Old 05-10-2013, 08:03 AM
Chatham036's Avatar
Quoted: 131 Post(s)
Codes
Thanks y"all
DTS Articles - 6.0L EGR Valve Cleaning
DTS Articles - ICP Sensor Failures
Lilpooh was spot on with the codes.
before we start discussing options, what type of evolution do you have? Basic, CS, or CTS?
Comments or opinions expressed by me do not necessarily represent the views of PHP, its management, nor its employees. PHP is not responsible for, and disclaims any and all liability for the content of comments written by me.
Chatham036 is offline
post #7 of 13 Old 05-10-2013, 08:55 AM Thread Starter
It's just the basic model.
NVRSFT is offline
post #8 of 13 Old 05-10-2013, 10:54 AM
Chatham036's Avatar
Quoted: 131 Post(s)
Good!
We can turn your EGR code off on your truck's ECM and rewrite your FICM with the proper code.
Look through our website www.phptune.com
If you have any questions just let me know!
post #9 of 13 Old 05-11-2013, 06:47 AM Thread Starter
I can't find the ICP
NVRSFT is offline
post #10 of 13 Old 05-11-2013, 07:12 AM Thread Starter
I found it. Thanks to YouTube. The icp plug had some oil inside the plug, but not a round it. Also no oil around the sensor.
NVRSFT is offline
