tranny upgrade - Ford Powerstroke Diesel Forum
post #1 of 8 Old 02-27-2008, 06:27 PM Thread Starter
tranny upgrade
im wanting to work on my transmision. i would like to get a complete flush and then a deep pan and new cooler. who has the best kit and pan. and would you have to replace the stock cooler or is it used in addition to the new cooler.
2004 Ford King Ranch
Crew Cab Dually
Chestnut Metallic
6.0 Diesel
PS2 with Customized Caddy
MBRP 4" Dual Exhausts
Zoodad Mod
Cat Delete Pipe
ARP Headstuds
Muffler Delete Pipe
ISSPRO Enhanced Visibility White Faced Blue Pointers
Boost, Pyro, Trans, Rear Diff
SCT LIVEWIRE(custom tunes later)
Mismatched Camper Top
:burnout
ncbowhunter is offline
post #2 of 8 Old 02-27-2008, 06:30 PM
i would not reccomend the deep pan...im not a believer... some people are...some people arent..
i would however reccomend putting an additional cooler on....dont get rid of your existing one...just put another in line with what you already have!!
mschn99 is offline
post #3 of 8 Old 02-27-2008, 06:38 PM Thread Starter
thanks marc that was a quick reply! my tranny temps are hitting 170 with no load and im getting concerned. i was hoping to gain every possible advantage. im not happy about the prices or the extra 8 qts. of fluid that i would have to buy. my brother also thinks the deep pan may be to low and bottom out on curbs or bumps.
Crew Cab Dually
Chestnut Metallic
6.0 Diesel
Zoodad Mod
Cat Delete Pipe
ARP Headstuds
Muffler Delete Pipe
:burnout
post #4 of 8 Old 02-27-2008, 06:41 PM
with a torqshift you can basically add 10 degrees to your temps...so your not all that hot empty...and you can run up to 210 towing.....
the problem IMO with a deeper pan is that even though it takes longer for that fluid to get hot.....when it does get warm it takes way longer to cool down...
mschn99 is offline
post #5 of 8 Old 02-27-2008, 06:43 PM
bluestroker's Avatar
good info thanks marc
Ricky
Dirty South Strokers
2003 F-350 Crew Cab 4x4
SCT Custom Tuned, Leveling Kit, BFG All Terrain T/A KO 315-75-16, 06' Seats, Zoodad Mod, Dual Silverline Exaust, AFE Cold Air Intake, Fog Light/Highbeam Mod, Edge Insight, 05-07 Polished Intake Elbow, Throttle Body Delete, ARP Headstuds, EGR Blocked Off
bluestroker is offline
post #6 of 8 Old 02-27-2008, 06:57 PM
jjames25's Avatar
shouldnt you get better heat exchange through the alluminum pan though?
2oo6 f350
6" procomp lift, Dual steering stabilizer
predator zoodad
accufab elbow, duals no cat or muffler
airaid intake, 17" motometals 35" toyo m/t's
alpine iva w205 deck, SCT xcal2
carriage works billet grill ,rodadeaco positive air shutdown
300 amp lincoln welder in the back
harley headlights in the box
fox 2.0 piggyback shocks in the box
2003 Dodge 3500 5.9 cummins
AEM intake, dual mitre cut stacks, Edge EZ , Smarty programmer, Webasto heater
jjames25 is offline
post #7 of 8 Old 02-27-2008, 06:57 PM Thread Starter
wow. its funny i know more now but less about what i want to do.
Crew Cab Dually
Chestnut Metallic
6.0 Diesel
Zoodad Mod
Cat Delete Pipe
ARP Headstuds
Muffler Delete Pipe
:burnout
post #8 of 8 Old 02-27-2008, 06:58 PM
the pan thats already on all torqshifts is aluminum...or at least some type of light alloy....
mschn99 is offline
